Hi everyone, Does anyone know how I could log in to the dashboard? For example, when I enter the dashboard, the username and password or add user option appears and the tabs or submenus are disabled until I enter the correct username and password. Something like in this video...
Have you asked the author of the video ?
I already did it a long time ago, I found another video but the information is given to me if I sign up for a course.
If you search the forum for dashboard login you will find lots of info.
But depending on your needs you could just take a look at this section of the docs, it may be all you need.
https://nodered.org/docs/user-guide/runtime/securing-node-red#usernamepassword-based-authentication
Hi @Mafi , I've used this example for phyunsj, I did some changes for my application, but It could be a well base to start and helps you!
node-red-dashboard-login
