Log is seen as an Error
Hello ,
I have this code and Error and I need to make this proiect done by today.
I have a Temp sensor on arduino how is connect with raspberry pi 4 and node red
Thx
log is not a built-in function.
As it looks like you are trying to do a logarithm, then you want to use Math.log() - https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Math/log
Hi ,
When I do that the console says “function tried to send a message of type number “
That is because you are returning just a Number and not a valid message object.
Instead of return temp, you should do:
msg.payload = temp;
