[{"id":"2cb0b5ff.4c045a","type":"function","z":"ea862e4d.78d9a","name":"s_m_3","func":" s_m_3=global.get("s_m_3")\n switch(s_m_3){\n case 0:\n vermelho = {payload:false};\n amarelo = {payload:true};\n verde = {payload:false}; \n vermelhoP = {payload:true};\n verdeP ={payload:false};\n break\n case 1:\n vermelho = {payload:true};\n amarelo = {payload:false};\n verde = {payload:false};\n vermelhoP = {payload:false};\n verdeP ={payload:true};\n break\n}\n s_m_3=s_m_3+1;\nreturn [vermelho,amarelo,verde,vermelhoP,verdeP];","outputs":5,"noerr":0,"x":1650,"y":1680,"wires":[["85f73462.1ee428"],["540483fb.32a93c"],["5c5a9a9.6728064"],["edb27b78.f94118"],["bb7052a6.54789"]]},{"id":"85f73462.1ee428","type":"ui_switch","z":"ea862e4d.78d9a","name":"vermelho","label":"","group":"e2f8a7f8.7b2608","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-circle","oncolor":"red","offvalue":"false","offvalueType":"bool","officon":"fa-circle-o","offcolor":"red","x":1820,"y":1600,"wires":[["a2047faa.aceab"]]},{"id":"540483fb.32a93c","type":"ui_switch","z":"ea862e4d.78d9a","name":"amarelo","label":"","group":"e2f8a7f8.7b2608","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-circle","oncolor":"yellow","offvalue":"false","offvalueType":"bool","officon":"fa-circle-o","offcolor":"yellow","x":1820,"y":1640,"wires":[["a2047faa.aceab"]]},{"id":"5c5a9a9.6728064","type":"ui_switch","z":"ea862e4d.78d9a","name":"verde","label":"","group":"e2f8a7f8.7b2608","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-circle","oncolor":"green","offvalue":"false","offvalueType":"bool","officon":"fa-circle-o","offcolor":"green","x":1810,"y":1680,"wires":[["a2047faa.aceab"]]},{"id":"edb27b78.f94118","type":"ui_switch","z":"ea862e4d.78d9a","name":"vermelhoP","label":"","group":"e2f8a7f8.7b2608","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-circle","oncolor":"red","offvalue":"false","offvalueType":"bool","officon":"fa-circle-o","offcolor":"red","x":1830,"y":1720,"wires":[["a2047faa.aceab"]]},{"id":"bb7052a6.54789","type":"ui_switch","z":"ea862e4d.78d9a","name":"verdeP","label":"","group":"e2f8a7f8.7b2608","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"fa-circle","oncolor":"green","offvalue":"false","offvalueType":"bool","officon":"fa-circle-o","offcolor":"green","x":1820,"y":1760,"wires":[["a2047faa.aceab"]]},{"id":"cc536135.5673e","type":"function","z":"ea862e4d.78d9a","name":"","func":"s_m_3=global.get("s_m_3")\nmsg={payload:s_m_3} \nreturn msg\n","outputs":1,"noerr":0,"x":1370,"y":1680,"wires":[["ca02d548.e1f6c8"]]},{"id":"a2047faa.aceab","type":"debug","z":"ea862e4d.78d9a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":2030,"y":1680,"wires":},{"id":"ca02d548.e1f6c8","type":"function","z":"ea862e4d.78d9a","name":"","func":"var s_m_3;\nwhile(button,false)\nglobal.get(s_m_3)\nreturn msg;","outputs":1,"noerr":0,"x":1510,"y":1680,"wires":[["2cb0b5ff.4c045a"]]},{"id":"97d0bc00.147998","type":"inject","z":"ea862e4d.78d9a","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1220,"y":1680,"wires":[["cc536135.5673e"]]},{"id":"983245d8.db2798","type":"function","z":"ea862e4d.78d9a","name":"show select language","func":"msg.payload={\n "group": {\n "hide": [\n "grupo Login_Ledlogin",\n "grupo Login_LoginPT",\n "grupo Login_LoginENG"\n ],\n "show": [\n "grupo Login_selectlanguage"\n ]\n }\n}\nflow.set("showselectlanguage", msg.payload);\nreturn msg","outputs":1,"noerr":0,"x":1640,"y":2220,"wires":[]},{"id":"83cefac9.571988","type":"function","z":"ea862e4d.78d9a","name":"show Ledlogin","func":"msg.payload={\n "group": {\n "hide": [\n "grupo Login_LoginPT",\n "grupo Login_selectlanguage",\n "grupo Login_LoginENG"\n ],\n "show": [\n "grupo Login_Ledlogin"\n ]\n }\n}\nflow.set("showLedlogin", msg.payload);\nreturn msg","outputs":1,"noerr":0,"x":1620,"y":2380,"wires":[]},{"id":"6cbf4902.7d5d68","type":"inject","z":"ea862e4d.78d9a","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1400,"y":2300,"wires":[["83cefac9.571988","18028def.ce9072","983245d8.db2798","71be531b.07df0c","76e4ccd8.1a9744"]]},{"id":"18028def.ce9072","type":"ui_ui_control","z":"ea862e4d.78d9a","name":"Go to Ledlogin","x":1620,"y":2300,"wires":[]},{"id":"765f2943.533178","type":"comment","z":"ea862e4d.78d9a","name":"hide and show","info":"","x":1570,"y":2160,"wires":},{"id":"4906e63c.534118","type":"comment","z":"ea862e4d.78d9a","name":"Led","info":"","x":1310,"y":1980,"wires":},{"id":"97710329.2f1f3","type":"comment","z":"ea862e4d.78d9a","name":"Pt","info":"","x":670,"y":1800,"wires":},{"id":"47338f23.1b987","type":"comment","z":"ea862e4d.78d9a","name":"Eng","info":"","x":670,"y":1340,"wires":},{"id":"f8766fbb.3682","type":"switch","z":"ea862e4d.78d9a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Welcome User","vt":"str"},{"t":"eq","v":"Access Denied","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":410,"y":1440,"wires":[["144dd842.889c58"],["7c1fc247.98340c"]]},{"id":"7c1fc247.98340c","type":"function","z":"ea862e4d.78d9a","name":"Access denied","func":"msg.payload = "Access Denied"\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":1460,"wires":[["eea3e302.52424"]]},{"id":"585e77b9.16d258","type":"ui_ui_control","z":"ea862e4d.78d9a","name":"Go to Ledlogin","x":780,"y":1420,"wires":[]},{"id":"eea3e302.52424","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"Details","topic":"unable to login","name":"unable to login","x":780,"y":1460,"wires":[["818a412c.c574d"]]},{"id":"e5255501.9ef618","type":"ui_form","z":"ea862e4d.78d9a","name":"","label":"","group":"718c80c.3c4bf8","order":0,"width":0,"height":0,"options":[{"label":"username","value":"username","type":"text","required":true},{"label":"password","value":"password","type":"password","required":true},{"label":"Remember me","value":"remember me","type":"checkbox","required":true}],"formValue":{"username":"","password":"","remember me":false},"payload":"","submit":"OK","cancel":"CANCEL","topic":"","x":330,"y":1500,"wires":[["42c687f4.12e5f8","c5f78682.a81988"]]},{"id":"cb6ed982.056618","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"Is Right","cancel":"Is Not Right","topic":"What to do ?","name":"Remember It","x":670,"y":1380,"wires":[["8660a237.39f64"]]},{"id":"76fbc2b1.e9b67c","type":"function","z":"ea862e4d.78d9a","name":"","func":"msg.payload = "Remember It:angry:"\nreturn msg;","outputs":1,"noerr":0,"x":510,"y":1380,"wires":[["cb6ed982.056618"]]},{"id":"3fcab705.801b08","type":"ui_button","z":"ea862e4d.78d9a","name":"button forgot","group":"718c80c.3c4bf8","order":0,"width":0,"height":0,"passthru":false,"label":"Forgot your password?
","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":350,"y":1380,"wires":[["76fbc2b1.e9b67c"]]},{"id":"1a0da4a7.5fdd5b","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"Look!!","name":"too bad for you!!","x":1140,"y":1380,"wires":[]},{"id":"870d6346.0db6a","type":"function","z":"ea862e4d.78d9a","name":"","func":"msg.payload = "too bad for you!
"\nreturn msg;","outputs":1,"noerr":0,"x":970,"y":1380,"wires":[["1a0da4a7.5fdd5b"]]},{"id":"8660a237.39f64","type":"switch","z":"ea862e4d.78d9a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Is Not Right","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":830,"y":1380,"wires":[["870d6346.0db6a"]]},{"id":"2cf27c89.b6abb4","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"Look!!","name":"you've write bad you want me to tell what!!","x":1340,"y":1460,"wires":[]},{"id":"3b5b49f3.5987f6","type":"function","z":"ea862e4d.78d9a","name":"","func":"msg.payload = "you've write bad you want me to tell what!!
"\nreturn msg;","outputs":1,"noerr":0,"x":1090,"y":1460,"wires":[["2cf27c89.b6abb4"]]},{"id":"818a412c.c574d","type":"switch","z":"ea862e4d.78d9a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Details","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":950,"y":1460,"wires":[["3b5b49f3.5987f6"]]},{"id":"144dd842.889c58","type":"function","z":"ea862e4d.78d9a","name":"Welcome user","func":"msg.payload= "Welcome User"\nflow.get("showLedlogin")\nreturn msg","outputs":1,"noerr":0,"x":580,"y":1420,"wires":[["585e77b9.16d258"]]},{"id":"3243ed26.dce3c2","type":"function","z":"ea862e4d.78d9a","name":"","func":"var accounts= [{username:"admin",password:"admin"}];\n\nvar indice\nvar username=flow.get("user")\nvar password=flow.get("pass")\n\nfor (indice = 0; indice<accounts.length;indice++){\n if(username == accounts[indice].username && password == accounts[indice].password){\n msg.payload = "Welcome User"\n }\n else\n msg.payload = "Access Denied";\n}\nreturn msg;","outputs":1,"noerr":0,"x":610,"y":1500,"wires":[["32d70e40.e24102"]]},{"id":"209e660d.ffe25a","type":"link in","z":"ea862e4d.78d9a","name":"","links":["32d70e40.e24102"],"x":295,"y":1440,"wires":[["f8766fbb.3682"]]},{"id":"32d70e40.e24102","type":"link out","z":"ea862e4d.78d9a","name":"","links":["209e660d.ffe25a"],"x":715,"y":1500,"wires":},{"id":"c5f78682.a81988","type":"ui_dropdown","z":"ea862e4d.78d9a","name":"selectlanguage","label":"select language","place":"Select option","group":"e8fcd7a9.82a9b8","order":0,"width":0,"height":0,"passthru":false,"options":[{"label":"English","value":"English","type":"str"},{"label":"Português","value":"Português","type":"str"}],"payload":"","topic":"selectlanguage","x":740,"y":1680,"wires":[]},{"id":"7699d15a.f2683","type":"switch","z":"ea862e4d.78d9a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Bem-vindo","vt":"str"},{"t":"eq","v":"Acesso negado","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":1940,"wires":[["da71d35e.6bcba"],["3d517638.13090a"]]},{"id":"3d517638.13090a","type":"function","z":"ea862e4d.78d9a","name":"Acesso negado","func":"msg.payload = "Acesso negado"\nreturn msg;","outputs":1,"noerr":0,"x":600,"y":1960,"wires":[["a6b9dc2b.e1ea3"]]},{"id":"a6b9dc2b.e1ea3","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"Detalhes","topic":"falha de autenticação","name":"falha de autenticação","x":820,"y":1960,"wires":[["25e3cf72.d5adf"]]},{"id":"e3121397.2be29","type":"ui_form","z":"ea862e4d.78d9a","name":"","label":"","group":"8324f859.ea70e8","order":0,"width":0,"height":0,"options":[{"label":"utilizador","value":"utilizador","type":"text","required":true},{"label":"palavra-passe","value":"palavrapasse","type":"password","required":true},{"label":"guardar senha","value":"guardar senha","type":"checkbox","required":true}],"formValue":{"utilizador":"","palavrapasse":"","guardar senha":false},"payload":"","submit":"OK","cancel":"CANCELAR","topic":"","x":350,"y":1880,"wires":[["8ebba165.5aeb6","c5f78682.a81988"]]},{"id":"cd8a9310.7571f","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"Tem Razão","cancel":"Não tem razão","topic":"O que fazer ?","name":"Lembrasses-te","x":700,"y":2000,"wires":[["e3633d78.fd57f"]]},{"id":"e5d53f96.b57b9","type":"function","z":"ea862e4d.78d9a","name":"","func":"msg.payload = "Lembrasses-te:angry:"\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":2000,"wires":[["cd8a9310.7571f"]]},{"id":"809f6d52.010c1","type":"ui_button","z":"ea862e4d.78d9a","name":"button forgot","group":"8324f859.ea70e8","order":0,"width":0,"height":0,"passthru":false,"label":"Esqueces-te da palavra-passe?
","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":370,"y":2000,"wires":[["e5d53f96.b57b9"]]},{"id":"77360c5.6a8d9f4","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"Olha!!","name":"Temos pena!","x":1170,"y":2000,"wires":[]},{"id":"58602fbf.c0638","type":"function","z":"ea862e4d.78d9a","name":"","func":"msg.payload = "Temos pena!
"\nreturn msg;","outputs":1,"noerr":0,"x":1010,"y":2000,"wires":[["77360c5.6a8d9f4"]]},{"id":"e3633d78.fd57f","type":"switch","z":"ea862e4d.78d9a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Não tem razão","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":870,"y":2000,"wires":[["58602fbf.c0638"]]},{"id":"fe52547d.10b248","type":"ui_toast","z":"ea862e4d.78d9a","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"Olha!!","name":"Temos pena!","x":1310,"y":1960,"wires":[]},{"id":"634c1d7d.ee0dd4","type":"function","z":"ea862e4d.78d9a","name":"","func":"msg.payload = "Escreves-te mal queres que diga o quê!!
"\nreturn msg;","outputs":1,"noerr":0,"x":1150,"y":1960,"wires":[["fe52547d.10b248"]]},{"id":"25e3cf72.d5adf","type":"switch","z":"ea862e4d.78d9a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Detalhes","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1010,"y":1960,"wires":[["634c1d7d.ee0dd4"]]},{"id":"da71d35e.6bcba","type":"function","z":"ea862e4d.78d9a","name":"Bem-vindo","func":"msg.payload= "Bem-vindo"\nflow.get("showLedlogin")\nreturn msg","outputs":1,"noerr":0,"x":590,"y":1920,"wires":[["fd4e3f75.2e973"]]},{"id":"db0b4aa3.bcbdb8","type":"function","z":"ea862e4d.78d9a","name":"","func":"var accounts= [{utilizador:"admin",palavrapasse:"admin"}];\n\nvar indice\nvar utilizador=flow.get("user")\nvar palavrapasse=flow.get("pass")\n\nfor (indice = 0; indice<accounts.length;indice++){\n if(utilizador == accounts[indice].utilizador && palavrapasse == accounts[indice].palavrapasse){\n msg.payload = "Bem-vindo"\n }\n else\n msg.payload = "Acesso negado";\n}\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":1880,"wires":[["21ccd87c.3bc9c8"]]},{"id":"c769578c.603498","type":"link in","z":"ea862e4d.78d9a","name":"","links":["21ccd87c.3bc9c8"],"x":315,"y":1940,"wires":[["7699d15a.f2683"]]},{"id":"21ccd87c.3bc9c8","type":"link out","z":"ea862e4d.78d9a","name":"","links":["c769578c.603498"],"x":735,"y":1880,"wires":},{"id":"a1af2f07.6b1eb","type":"inject","z":"ea862e4d.78d9a","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"1","x":150,"y":1680,"wires":[["ad8553aa.d02f7"]]},{"id":"fc25f9e9.b89418","type":"comment","z":"ea862e4d.78d9a","name":"Os flows.set dos Login","info":"","x":1560,"y":2060,"wires":},{"id":"71be531b.07df0c","type":"function","z":"ea862e4d.78d9a","name":"show PT","func":"msg.payload={\n "group": {\n "hide": [\n "grupo Login_Ledlogin",\n "grupo Login_selectlanguage",\n "grupo Login_LoginENG"\n ],\n "show": [\n "grupo Login_LoginPT"\n ]\n }\n}\nflow.set("showLoginPT", msg.payload);\nreturn msg","outputs":1,"noerr":0,"x":1600,"y":2260,"wires":[]},{"id":"76e4ccd8.1a9744","type":"function","z":"ea862e4d.78d9a","name":"show Eng","func":"msg.payload={\n "group": {\n "hide": [\n "grupo Login_Ledlogin",\n "grupo Login_selectlanguage",\n "grupo Login_LoginPT"\n ],\n "show": [\n "grupo Login_LoginENG"\n ]\n }\n}\nflow.set("showLoginENG", msg.payload);\nreturn msg","outputs":1,"noerr":0,"x":1600,"y":2340,"wires":[]},{"id":"ad8553aa.d02f7","type":"function","z":"ea862e4d.78d9a","name":"","func":"flow.get("showselectlanguage")\nreturn msg","outputs":1,"noerr":0,"x":310,"y":1680,"wires":[["8ef44c88.5324a"]]},{"id":"42c687f4.12e5f8","type":"function","z":"ea862e4d.78d9a","name":"","func":"flow.set("user",msg.payload.username)\nflow.set("pass",msg.payload.password)\n\nflow.get ("showLoginENG")\nreturn msg","outputs":1,"noerr":0,"x":470,"y":1500,"wires":[["3243ed26.dce3c2"]]},{"id":"8ebba165.5aeb6","type":"function","z":"ea862e4d.78d9a","name":"","func":"flow.set("user",msg.payload.username)\nflow.set("pass",msg.payload.password)\n\nflow.get ("showLoginPT")\nreturn msg","outputs":1,"noerr":0,"x":490,"y":1880,"wires":[["db0b4aa3.bcbdb8"]]},{"id":"a27c05e8.809a78","type":"comment","z":"ea862e4d.78d9a","name":"first step","info":"","x":120,"y":1640,"wires":},{"id":"17ffd3f9.1ef07c","type":"comment","z":"ea862e4d.78d9a","name":"select language","info":"","x":820,"y":1620,"wires":},{"id":"7abb851d.009cac","type":"comment","z":"ea862e4d.78d9a","name":"second step Login in english","info":"","x":540,"y":1540,"wires":},{"id":"55d158ef.246a28","type":"comment","z":"ea862e4d.78d9a","name":"second step login in portuguese","info":"","x":530,"y":1840,"wires":},{"id":"3094dd15.2f21b2","type":"comment","z":"ea862e4d.78d9a","name":"third step Ledlogin","info":"","x":1050,"y":1680,"wires":},{"id":"fd4e3f75.2e973","type":"ui_ui_control","z":"ea862e4d.78d9a","name":"Go to Ledlogin","x":800,"y":1920,"wires":[]},{"id":"3375f52d.ba93aa","type":"comment","z":"ea862e4d.78d9a","name":"how's the sytem need's to work","info":"the firs't think to do is it to show only the \nselect language and i chose one option and then \ngo directly to the login in english/portuguese\nwhen i fill all campus with admin it will go directy\nto Ledlogin\n\nif you doesn't understanded\n\nimagine a... social post like gmail\nyou need to insert your language and then Login\nand then the emais are the Led's\n","x":1010,"y":1580,"wires":},{"id":"8ef44c88.5324a","type":"ui_ui_control","z":"ea862e4d.78d9a","name":"go to select language","x":500,"y":1680,"wires":[["c5f78682.a81988"]]},{"id":"e2f8a7f8.7b2608","type":"ui_group","z":"","name":"Ledlogin","tab":"eea06067.374ab","order":3,"disp":true,"width":"6","collapse":false},{"id":"718c80c.3c4bf8","type":"ui_group","z":"","name":"LoginENG","tab":"eea06067.374ab","order":4,"disp":true,"width":"6","collapse":false},{"id":"e8fcd7a9.82a9b8","type":"ui_group","z":"","name":"selectlanguage","tab":"eea06067.374ab","order":2,"disp":true,"width":"6","collapse":false},{"id":"8324f859.ea70e8","type":"ui_group","z":"","name":"LoginPT","tab":"eea06067.374ab","order":3,"disp":true,"width":"6","collapse":false},{"id":"eea06067.374ab","type":"ui_tab","z":"","name":"grupo Login","icon":"dashboard","order":7}]Preformatted text
Hi @Lavio
Please read this post on how to properly share flows on the forum - How to share code or flow json
You will also have to tell us what the problem you are seeing is and what question you are asking.
thw problem is the hide and show it just don't obey
What hide? What show? Sorry, but you cannot just post a flow and expect us to import it, study it and guess what problem you are hitting.
Please describe what you are trying to do, what does work and doesn't work.
the best way to say it it´s to show an exercise
[{"id":"9c0e5e4b.f03f2","type":"ui_button","z":"2fc22abd.e55b26","name":"","group":"c1177948.329888","order":0,"width":0,"height":0,"passthru":false,"label":"button1","color":"","bgcolor":"","icon":"","payload":"{"group":{"hide":["Home_Group_2","Home_Group_3"],"show":["Home_Group_1"]}}","payloadType":"json","topic":"","x":340,"y":360,"wires":[["c2b3dce3.98d64"]]},{"id":"54b6230a.28f49c","type":"ui_button","z":"2fc22abd.e55b26","name":"","group":"c1177948.329888","order":0,"width":0,"height":0,"passthru":false,"label":"button2","color":"","bgcolor":"","icon":"","payload":"{"group":{"hide":["Home_Group_1","Home_Group_3"],"show":["Home_Group_2"]}}","payloadType":"json","topic":"","x":340,"y":400,"wires":[["c2b3dce3.98d64"]]},{"id":"d47d6c39.b66cf","type":"ui_button","z":"2fc22abd.e55b26","name":"","group":"c1177948.329888","order":0,"width":0,"height":0,"passthru":false,"label":"button3","color":"","bgcolor":"","icon":"","payload":"{"group":{"hide":["Home_Group_1","Home_Group_2"],"show":["Home_Group_3"]}}","payloadType":"json","topic":"","x":340,"y":440,"wires":[["c2b3dce3.98d64"]]},{"id":"d52a1aab.ed0178","type":"ui_gauge","z":"2fc22abd.e55b26","name":"","group":"736fdfff.35443","order":0,"width":0,"height":0,"gtype":"gage","title":"Gauge","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":910,"y":260,"wires":},{"id":"4664168f.205ce8","type":"ui_template","z":"2fc22abd.e55b26","group":"bb9aa014.09247","name":"","order":0,"width":"6","height":"3","format":"This is the start group.
\nPress button 2 to move to the next group.
\nThen slide the slider.","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":920,"y":200,"wires":[]},{"id":"f57a56cc.72ac58","type":"ui_button","z":"2fc22abd.e55b26","name":"","group":"f5cee47a.823098","order":2,"width":0,"height":0,"passthru":false,"label":"Reset","color":"","bgcolor":"","icon":"","payload":"{"group":{"hide":["Home_Group_2","Home_Group_3"],"show":["Home_Group_1"]}}","payloadType":"json","topic":"","x":910,"y":360,"wires":[["c2b3dce3.98d64"]]},{"id":"c2b3dce3.98d64","type":"ui_ui_control","z":"2fc22abd.e55b26","name":"","x":740,"y":440,"wires":[]},{"id":"489b02ff.5c8afc","type":"ui_slider","z":"2fc22abd.e55b26","name":"","label":"slider","group":"736fdfff.35443","order":0,"width":0,"height":0,"passthru":false,"topic":"","min":0,"max":10,"step":1,"x":550,"y":240,"wires":[["d52a1aab.ed0178","701866d3.2aedd8"]]},{"id":"51ceebb8.7b1264","type":"ui_template","z":"2fc22abd.e55b26","group":"f5cee47a.823098","name":"","order":1,"width":"6","height":"3","format":"Slider reached > 7 = Passed\nHit Reset to go back to stage 1\nOr wait 10 seconds.","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":920,"y":320,"wires":[]},{"id":"701866d3.2aedd8","type":"function","z":"2fc22abd.e55b26","name":"","func":"if (msg.payload > 7) {\n m2 = {payload : 0};\n msg.payload = {"group":{"hide":["Home_Group_1","Home_Group_2"],"show":["Home_Group_3"]}};\n return [ m2, msg];\n}\nreturn null;","outputs":2,"noerr":0,"x":550,"y":300,"wires":[["489b02ff.5c8afc","d52a1aab.ed0178"],["a50f97af.848d48"]]},{"id":"2830647.a8b499c","type":"inject","z":"2fc22abd.e55b26","name":"","topic":"","payload":"{"group":{"hide":["Home_Group_2","Home_Group_3"],"show":["Home_Group_1"]}}","payloadType":"json","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":350,"y":320,"wires":[["c2b3dce3.98d64"]]},{"id":"a50f97af.848d48","type":"trigger","z":"2fc22abd.e55b26","op1":"","op2":"{"group":{"hide":["Home_Group_2","Home_Group_3"],"show":["Home_Group_1"]}}","op1type":"pay","op2type":"json","duration":"10","extend":false,"units":"s","reset":"","bytopic":"all","name":"","x":630,"y":360,"wires":[["c2b3dce3.98d64"]]},{"id":"c1177948.329888","type":"ui_group","z":"","name":"Menu","tab":"4c06c005.59403","disp":true,"width":"6","collapse":false},{"id":"736fdfff.35443","type":"ui_group","z":"","name":"Group 2","tab":"4c06c005.59403","order":3,"disp":true,"width":"6","collapse":false},{"id":"bb9aa014.09247","type":"ui_group","z":"","name":"Group 1","tab":"4c06c005.59403","order":2,"disp":true,"width":"6","collapse":false},{"id":"f5cee47a.823098","type":"ui_group","z":"","name":"Group 3","tab":"4c06c005.59403","order":4,"disp":true,"width":"6","collapse":false},{"id":"4c06c005.59403","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]Preformatted text
No, that is not the best way.
Please describe what you are trying to do without requiring me to import a flow and spend time trying to figure out what it is doing because you have not shared any information.
what i have in the original it´s a basic login
1º you chose your language and then the "hide" will go hide the group of the select language and "show" the Login with the language you chose after you fill the password and username (with "admin") will hide and then will show the Ledlogin S_M_3(it's a traffic Light)
