Long code in function node...how to wrap
Noob question here....I have a very long string of code within a function node that is difficult to read and cannot figure out how to "wrap" the code inside the window without breaking the functionality. For instance...msg.topic is hundreds of characters in length and I am getting confused by using the scroll bar and would like to format the window for a more plessant means to check for syntax errors etc.
Can someone please provide the characters/syntax for helping me achieve this? Thanks in advance!
Why do you need such a long topic?
It is an insert statement into a SQL database:
msg.topic="INSERT INTO electrodacus (SOC,cell_1,cell_2,cell_3,cell_4,Batt_Amps,Ext_Load) VALUES ("+msg.payload.soc+""+msg.payload.cell1+","+msg.payload.cell2+","+msg.payload.cell3+","+msg.p```
etc....etc...etc...
Use template literals...
msg.topic=`
VALUES
(${msg.payload.soc}, ${msg.payload.etc}, ...
What database? Mysql? MSSQL? Postgres?
I ask because the better/safer way to build a query is to use a parametrised query.
MYSQL and this is an insert statement
I have tried various iterations of using backticks but get an error of either "ER_WRONG_VALUE_COUNT_ON_ROW"
With this
msg.topic=
`INSERT INTO electrodacus
VALUES
("+msg.payload.soc+""+msg.payload.cell1+","+msg.payload.cell2+","+msg.payload.cell3+","+msg.payload.cell4+","+msg.payload.battAmps+","+msg.payload.extLoad+")`
msg.payload=[msg.payload.soc,msg.payload.cell1,msg.payload.cell2,msg.payload.cell3,msg.payload.cell4,msg.payload.battAmps];
Or
ER_PARSE_ERROR
with this
msg.topic=
`"INSERT INTO electrodacus
VALUES
("+msg.payload.soc+""+msg.payload.cell1+","+msg.payload.cell2+","+msg.payload.cell3+","+msg.payload.cell4+","+msg.payload.battAmps+","+msg.payload.extLoad+")"`
I missed the $ sign and corrected:
msg.topic=`
(SOC,cell_1, cell_2, cell_3, cell_4, Batt_Amps,Ext_Load)
VALUES
(${msg.payload.soc}, ${msg.payload.cell1}, ${msg.payload.cell2}, ${msg.payload.cell3}, ${msg.payload.cell4}, ${msg.payload.battAmps}, ${msg.payload.extLoad$}
But now get this error
"Error: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '' at line 4"
I have to watch my typing...had and extra $, removed and working...thank you so very much!!
msg.topic=`
VALUES
(${msg.payload.soc}, ${msg.payload.cell1}, ${msg.payload.cell2}, ${msg.payload.cell3}, ${msg.payload.cell4}, ${msg.payload.battAmps}, ${msg.payload.extLoad})
I am curious about this as well. I 'see' the syntax, but I do not 'understand' the syntax.
Can someone please explain the ` and the $ and the {}s ? And their function/use?
Joe
Look up 'Template Literals'
A simple code example should explain it...
const myName = " Joe";
const aStringVar = `Hello ${myName}`;
console.log(aStringVar);
//prints:    Hello Joe
This example ↑ is a bit simplistic but should spell out what is happening.
Here ↓ is another example to bolster the notion that inside of ${} is actually being evaluated...
const ninetyNine = 99;
function toHexadecimal(v) {
  return v.toString(16);
const result = `${ninetyNine + 1} decimal equals 0x${toHexadecimal(ninetyNine + 1)} hexadecimal`;
console.log(result);
//prints:   100 decimal equals 0x64 hexadecimal
This makes building strings with lots of dynamic values much more manageable.
