Looking for guidance to add a functional "delete" link to delete file(s) in a folder
Continuing the discussion from Unable to download files from the browser:
Hi everyone, i'm a newbiew to NodeRed and came across this post which is able to create a list from a folder and download link. it works great!
had tried to understand the codes and been playing around with it, however still unable to let the "delete" link to be functional.
<table>
    <th>Files found</th>
    {{#files}}
     <tr>
        <td> {{.}} </td>
        <td> <a href="/files/{{{.}}}">download</a>
        <td>
        <td> <a href="/delete/{{{.}}}">delete</a>
        <td>
    </tr>
    {{/files}}
</table>
did as above but lost of direction what can i do next to move on. had lots of trial and error to have more understanding but however what i get most of the time was as below. on the positive side was the filename returned (although with error) was the name intended to be deleted :joy:
"Cannot GET /delete/20220411.csv"
Thanks in advance! :blush:
Did you add an endpoint for /delete & hook that up to the necessary logic to perform the delete?
Hi Steve! thanks for the prompt response
        "id": "0829d2663c2cbbca",
        "type": "function",
        "z": "e582dbe7569c9c4e",
        "name": "Set base path",
        "func": "//restrict to c:\\temp\\\nvar basePath = flow.get(\"basePath\");\nvar filename = msg.req.params.fn;\n\n\nif(filename.includes(\"..\\\\\")){\n    msg.payload = \"Illegal file path\";\n    msg.statusCode = 405;//not allowed\n    return [null, msg];//fire output 2\n} else if(filename.includes(\"../\")){\n    msg.payload = \"Illegal file path\";\n    msg.statusCode = 405;//not allowed\n    return [null, msg];//fire output 2\n} \n//TODO: add more checks\n\nmsg.filename = basePath + filename;\nreturn [msg, null];//fire output 1\n\n\n",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1100,
        "y": 660,
                "11ed99d831349ff6",
                "6a8dcab2d3b975be"
                "b2f7eb8cfcba09d8"
        "id": "b2f7eb8cfcba09d8",
        "type": "http response",
        "statusCode": "",
        "headers": {},
        "x": 1410,
        "y": 720,
        "id": "11ed99d831349ff6",
        "type": "file in",
        "filename": "",
        "format": "",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "allProps": false,
        "x": 1320,
        "y": 660,
                "b2f7eb8cfcba09d8"
        "id": "740a73135bb53bb7",
        "type": "catch",
        "scope": null,
        "uncaught": false,
        "x": 880,
        "y": 720,
                "df88955353671807",
                "bcbc4da718e60095"
        "id": "df88955353671807",
        "type": "function",
        "name": "Set 404",
        "func": "msg.payload = msg.error;\nmsg.statusCode = 404;//resource not found\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1200,
        "y": 720,
                "b2f7eb8cfcba09d8"
        "id": "bcbc4da718e60095",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 1050,
        "y": 700,
        "id": "5ffcf157d5c4e561",
        "type": "ui_template",
        "group": "dfb4a60f.d788f8",
        "name": "ui_temlplate - present download links on dashboard",
        "order": 1,
        "width": "7",
        "height": "8",
        "format": "<div ng-bind-html=\"msg.payload\"></div>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": false,
        "templateScope": "local",
        "className": "",
        "x": 1310,
        "y": 800,
        "id": "5429470c045925c9",
        "type": "comment",
        "name": "Create http endpoint <nodered>/files/xxx  where xxx is the file name to download",
        "info": "",
        "x": 1040,
        "y": 620,
        "id": "f51f310fa49f72e3",
        "type": "http in",
        "url": "/files/:fn",
        "method": "get",
        "upload": false,
        "swaggerDoc": "",
        "x": 890,
        "y": 660,
                "0829d2663c2cbbca",
                "86e4b4968b4f185b"
        "id": "cede760ddd3693af",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "/home/orangepi/datalog/",
        "payloadType": "str",
        "x": 890,
        "y": 580,
                "db7cbbbe1ea13b1a"
        "id": "db7cbbbe1ea13b1a",
        "type": "change",
        "name": "store flow.basePath",
        "rules": [
                "t": "set",
                "p": "basePath",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1130,
        "y": 580,
        "id": "80825c1d79c2b94c",
        "type": "ui_ui_control",
        "events": "all",
        "x": 840,
        "y": 800,
                "c9c91dfef1e3aec8"
        "id": "0e39a125e27ab6c6",
        "type": "comment",
        "name": "Setup basePath",
        "info": "",
        "x": 840,
        "y": 540,
        "id": "1e4aca0214eb0cc6",
        "type": "comment",
        "name": "Get files in basePath and generate table",
        "info": "",
        "x": 910,
        "y": 760,
        "id": "ae8f44c9ddf01a9c",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 860,
        "y": 840,
                "c9c91dfef1e3aec8"
        "id": "d680804e3853c21b",
        "type": "template",
        "field": "payload",
        "fieldType": "msg",
        "format": "handlebars",
        "syntax": "mustache",
        "template": "<table>\n    <th>Files</th>\n    \n    {{#files}}\n     <tr>\n        <td> {{.}} </td>\n        <td> <a href=\"/files/{{{.}}}\">download</a>\n        <td>\n        <td> <a href=\"/delete/{{{.}}}\">delete</a>\n        <td>\n    </tr>\n    {{/files}}\n</table>",
        "output": "str",
        "x": 1040,
        "y": 840,
                "5ffcf157d5c4e561"
        "id": "c9c91dfef1e3aec8",
        "type": "fs-ops-dir",
        "path": "basePath",
        "pathType": "flow",
        "filter": "*.csv",
        "filterType": "str",
        "dir": "files",
        "dirType": "msg",
        "x": 1000,
        "y": 800,
                "d680804e3853c21b"
        "id": "86e4b4968b4f185b",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "statusType": "auto",
        "x": 1130,
        "y": 920,
        "id": "b20368ff6c391b0a",
        "type": "http in",
        "url": "/delete/:fn",
        "method": "delete",
        "upload": false,
        "swaggerDoc": "",
        "x": 870,
        "y": 960,
                "0829d2663c2cbbca"
        "id": "6a8dcab2d3b975be",
        "type": "fs-ops-delete",
        "path": "",
        "pathType": "str",
        "filename": "*",
        "filenameType": "msg",
        "x": 1330,
        "y": 940,
                "b2f7eb8cfcba09d8"
        "id": "dfb4a60f.d788f8",
        "type": "ui_group",
        "name": "Select files to download",
        "tab": "f2e6c77a41682d29",
        "order": 2,
        "disp": true,
        "width": "7",
        "collapse": false,
        "className": ""
        "id": "f2e6c77a41682d29",
        "type": "ui_tab",
        "name": "Page 2: Data",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
i had edited the template and simply added the http request node as above. i'm not sure if i missed out anything else.
added nodes are
  1. another http request node with delete
  2. fs-ops-delete node
do you mind to have a look at it?
thanks in advance!!
