Looking for something to happen within a time range
Hi. Impressed with Node Red, but can't get my mind round how to do this -
I want to trigger an event if the kettle (monitored by POW2) has not been used between 06:00 and 08:00 - that would be an anomaly.
Any guidance / ideas please?
To achieve that I would keep track of each time the kettle is used (probably I would save the last time in a function node's context) then at 0800 use an inject node to trigger a check on when it was last used. If that is more than two hours ago then send a message to take appropriate action.
Thanks Colin, hadn't thought of the logic in that way, I'll give it a go.
Looking at function node, can't see how to save last time in context? Could you expand on this please Colin?
Have a look at the docs on writing functions, in particular the section on storing data (but read all the rest if you have not already done so). The current date/time is available using something like
let now = new Date()
You can use different values of topic to distinguish between kettle operations and the input from the inject node.
Thanks Colin. That's my Christmas project sorted. Need some strong coffee and quiet time.
Different way of thinking.
  • At 6AM set a flag to warning (perhaps an mqtt topic called node-red/flag)
  • Any time the kettle is used the set the flag to normal
  • Check flag at 8AM if the flag is not normal set it to anomaly
  • Another flow can monitor flag (subscribe to node-red/flag). Perhaps a notification is set (email, tweet, txt, traffic light that follows the flag ...)
I use MQTT to allow multiple applications to use the information without interfering with each other.
Or....
At 6 fire a trigger node to send nothing right away, and its second output 2 hours later (8am). If the kettle is detected send a msg.reset to it to clear the waiting warning.
