Loops in node red
Hello Everyone ,
I am new to node-red
I am trying to create a flow in which i have to loop for condition and within loop i need to add sub flows based on value of loop .
ex --
index value -- sce1 then subflow sc1 likewise .
Any help willl be great .
thnks/
Welcome @rjdugar
Do you mean you want each each iteration of the loop to call a different subflow instance?
One way would be to have a counter property on the message that you increment each time you loop, and then use a Switch node to route the message to the appropriate subflow instance node based on the counters value.
Does that make sense?
(btw, have moved to the #general category as #development is for development of Node-RED itself, not general usage questions)
thanks will note tht .
