Loops inside a node
I am delving into loops for some reason.
I send a payload (number) and the node spits out that many messages.
(Contents not important)
So for now this is the code:
let x = msg.payload;
let y = 0;
context.set("COUNT",x);   //  Not really needed?
while (y < x)
    y = y + 1;
    node.warn(y);
//    node.send(y);    //  Not sure on structure.   But.....
    delay(1000);
But when I inject a value, I get this as an error:
TypeError: Cannot read property 'startsWith' of undefined
I've seen this before, but can't remember where and why.
Putting that aside, what am I missing on the loop?
Thanks in advance.
EDIT
Ok, found first problem in line:
Originally I put a . rather than a ,.
But now the delay isn't happy.
How do I delay?
Delay as such is not available in javascript. You have to use setTimeout in some way. You could eventually write a function with the name 'delay' but inside, you have to use setTimeout
Yeah, I was searching and found setTimeout but the docs on it are above my skill set to read and understand. :frowning:
let y = 0;
function f(x,y) {
    y += 1;
    node.warn(y);
    if(y < x){
        setTimeout( f, 1000, x, y );
f(x,y);
Thanks.
I still need to learn more. This saved me a lot of mucking about.
Good to hear, I anyway had that code in front of me recently, I then needed a similar delay feature as well :wink:
You might be better to split the loop out into a number of nodes and use a Delay node to do the delay.
I do agree @Colin. Alas I was wanting to just optimise the screen size.
Though of course: I could use a sub flow node.
It is only for a very small specific use and it is just in testing phase for now.
I may not use/need it anyway.
It just seems what @krambriw showed me is possibly the Goldilocks code.
