Lost connection to server, reconnecting... (DietPi)
Hi!
today I tried to install a fresh Node-RED on DietPi Bookworm, but immediately get the error message "Lost connection to server, reconnecting".
There is no Firewall active and everything else should be like "out-of-the-box".
System is
Node-Red v3.1.3
Node v21.6.1 (that's DietPi...)
and only mosquitto, ufw (disabled) and RPi.GPIO installed...
Any ideas, where I have to search for this problem?
Thanks in advance!
Florian
I would start by going back to supported version of nodejs, 18 or 20.
Seems - for me - not to be possible.
If I use the dietpi-software command I only get this versions...
Alright, I got it:
  1. uninstall node-red again
dietpi-software uninstall 122
  1. install Node.js (LTS should be best, right?)
curl -fsSL https://deb.nodesource.com/setup_lts.x | bash - &&
apt-get install -y nodejs
  1. install node-red via dietpi-software
dietpi-software install 122
Seems to work now, but I will go back 2 steps and try again, just to make sure, that this is the right way!
Thank you so far!
[EDIT]:
Didn't work. After a reboot Version 21.6.1 was the version, that node -v showed up...
I was wrong...
The httpAdminRoot was at "/Admin" - and opening "/admin" worked so far - except the websocket connection... How bad... :thinking:
