Make Leds on picture
Hello everyone !
How i can make a picture like that in dashboard such the G/R icon i want them Leds and controllling them by slider node in the same flow
There are at least 2 examples of this shared as Flows.
Here is the UIBUILDER based one:
https://flows.nodered.org/flow/89487d20c635d54d9b98d963656ce429
There was one for Dashboard as well I think - can't see it in the flows, must be in the forum somewhere.
In node-red-dashboard, you can use SVG via the node-red-contrib-ui-svg node - see the wiki here
What @TotallyInformation has suggested will work and is probably a more recent solution than node-red-contrib-ui-svg
I used node-red-contrib-ui-svg about 2-years ago to show the status of a group of four Rasberry Pi(es) in a mini cluster. I took a photo of the hardware on my phone and used that as the background image, then added led icons that I could switch between red and green. I'm sorry - at the moment I can't find the flow, but there are quite a few examples in the wiki-link that @Steve-Mcl has provided.
To be fair, the solutions should be much the same except that the ui version works with Dashboard 1 of course and mine works with UIBUILDER.
This one ?
Well done I was trying to find that posting on the Forum.
Now if I could find the Node-RED flow as well we would be sorted?
You are more than welcome to pop round to my house and help me look through the SSDs.
I've eventually found the source files for the Node-RED posting that @smanjunath211 found, and have made a posting on 'share your projects'. I hope someone can make use of it.
