Manage import module in function
Hi all,
I'm making a function to parse the msg files of outlook because node-red-contrib-mail-parse works only with eml file.
I'm using the module @kenjiuno/msgreader so I installed the module with npm in the node-red folder and I wrote in the settings.js the row msgreader:require('@kenjiuno/msgreader') in functionGlobalContext and I import it in my function node with const MsgReader = global.get('msgreader');
In a normal script this module can be imported with import MsgReader from '@kenjiuno/msgreader' and then it need to create the object with const testMsg = new MsgReader(msgFileBuffer).
In function Node I can't use import so I use const MsgReader = global.get('msgreader'); but the function try the error "TypeError: MsgReader is not a constructor" at the row const testMsg = new MsgReader(msgFileBuffer).
MsgReader is an export of the module @kenjiuno/msgreader so I modified const MsgReader = global.get('msgreader'); in const MsgReader = global.get('msgreader').MsgReader but I have the same error;
I think the problem is that the contruct import-from is not correctly interpreted by the global.get('msgreader') but I didn't understant how I can to translate import MsgReader from '@kenjiuno/msgreader' for node function of nodered.
Can you help me?
When facing problems like this, best to raise an issue in the authors github:
Usage with node.js · Issue #5 · HiraokaHyperTools/msgreader (github.com)
Great,
with the suggested workaround from the author it works good.
Thanks.
Can you please share so that other people know what the resolution was?
Sure, my function is
const MsgReaderOrExports = global.get('msgreader');
const MsgReader = MsgReaderOrExports.default || MsgReaderOrExports;
const testMsg = new MsgReader(msg.payload);
const testMsgInfo = testMsg.getFileData();
msg.payload = testMsgInfo;
in the row const testMsg = new MsgReader(msg.payload); msg.payload is the binary of the file that I extract with other function by the file received with a POST call
