Hi everybody,
I'm come back to you again.
To secure my project i want to manage my messages.
I use 2 arduinos with different name 1=CAL, 2=BAL,
On my sketch to send message by serial my messages start by CAL* or BAL*.
So all message cal(star) need to go arduino CAL and bal(star) got to arduino BAL.
The forum can't take the symbol star ?
You can find my sketchs for arduinos and my node.
ok 1112.json (25.6 KB)
Sketch calendar :
Typical pin layout used:MFRC522 Arduino Reader/PCD Uno/101Signal Pin Pin
RST/Reset RST 9
SPI SS SDA(SS) 10
SPI MOSI MOSI 11
SPI MISO MISO 12
SPI SCK SCK 13*/
//DECLARATION DES VARIABLES
#include <SPI.h>
#include <MFRC522.h>#define RelaiOuverture 7 // Pin 7 pour la ventouse magnétique
#define RelaiLeds 8 // Pin 8 pour le relai des LEDS
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout aboveString command;
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
int phase = 0;
int on_position = 0;
const byte uids[4][7] = {
{0x04, 0xfe, 0x36, 0xba, 0x6d, 0x67, 0x80},
{0x04, 0x9f, 0x36, 0xba, 0x6d, 0x67, 0x80},
{0x04, 0xa5, 0x36, 0xba, 0x6d, 0x67, 0x80},
bool stringComplete = false;MFRC522 mfrc522(SS_PIN, RST_PIN);
//DECLARATION DE LA CONFIGURATION INITIALE
void setup() {
Serial.begin(57600); // Configuration de la vitesse du port série 57600 bauds
SPI.begin(); // Initialisation du bus SPI
mfrc522.PCD_Init(); // Initialisation du capteur MFRC522 (RFID)
digitalWrite(RelaiOuverture, HIGH); // Pin 7 doit est être alimentée
pinMode(RelaiLeds, OUTPUT); // Pin 8 est une sortiedelay(2000); // Temps d'attente de l'initialisation 2 secondes
void reset_game() {
phase = 0;
on_position = 0;
}void sendMessage(String mesg) {
char charBuf[50];
mesg.toCharArray(charBuf, 50);
Serial.println(mesg);}
void loop() {
if (Serial.available()) {
command = Serial.readStringUntil('');
command.trim();
if (command.equals("CAL""LEDOPEN")) {
digitalWrite(RelaiLeds, HIGH);
digitalWrite(RelaiOuverture, LOW);
else if (command.equals("CAL"*"LEDCLOSE")) {
digitalWrite(RelaiLeds, LOW);
else {
Serial.print("Mauvais ordre");
Serial.print("Command: ");
Serial.println(command);
}delay(10);
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// A new card is present : read it
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
}// for phase 0 to 3 read cards & go to next phase :
if (phase <= 3) {
if ( (memcmp(uids[phase], mfrc522.uid.uidByte, 7) == 0) /and (horaire == HIGH)/) {
switch (on_position) {
case 0:
previousMillis = millis();
sendMessage("CALPHASE_" + String(phase) + "_" + String(on_position));
on_position = 1;
break;
case 1:
currentMillis = millis();
if (currentMillis > previousMillis + 1000) {
phase++;
on_position = 0;
break;
return;
}sendMessage("CALPLAYROCK");
sendMessage("CALFINISH");
reset_game();
Sketch Pierres:
#include "HX711.h"
int MINLOAD = 30; //Sensibilité de la pression à travaillerString message = "";
String command;
bool stringComplete = false;//CLASS SCALE - Programmation des balances
class _Scale {
private :
public :
HX711 scale;
int D;
int S;
long zero;_Scale(int D, int S) { this->D = D; this->S = S; this->scale.begin(D, S); this->scale.read(); this->zero = this->scale.read(); this->scale.tare(); } int getData() { long reading = 0; if (scale.is_ready()) { reading = scale.read() - this->zero; reading = int((90000 - reading) / 10000); } return (reading); }};
//FIN CLASS SCALE//BRANCHEMENT DES BALANCES ET LECTURE DE DONNEES
_Scale scales[6] = {
_Scale(2, 3),
_Scale(4, 5),
_Scale(6, 7),
_Scale(8, 9),
_Scale(10, 11),
_Scale(12, 13)
//FIN BRANCHEMENT BALANCE ET LECTURE DE DONNEESvoid sendMessage(String mesg) {
char charBuf[50];
void setup() {
}void loop() {
if (stringComplete) {
// manage message here :
message.trim();
if (message.substring(0, 6) == "BALMIN") {
MINLOAD = message.substring(7).toInt();
}//REset stuff : stringComplete = false; message = "";}
int nbp = 0;
String bals = "";
for (int i = 0; i < 6; i++) {
int p = scales[i].getData();
bals = bals + "|" + String(p);
if (p > MINLOAD) {
nbp += 1;
delay(10);
delay(1000);
sendMessage("BALT" + String(nbp));
sendMessage("BALB" + String(bals));}
void serialEvent() {
while (Serial.available()) {
char inChar = (char)Serial.read();
message += inChar;
if (inChar == '\n') {
stringComplete = true;
So i need to your help for make this. Thanks in advance !
NOTE : I can't show my "" on my code so it's CAL""LEDOPEN, CAL"*"LEDCLOSE without quotes.
