Manager variable two different instances
Dear all
I have developed an application using Dashboard 2 (flowfuse), and for many areas I have only one dashboard with many gauges. The operator can select the line and area. After that the gauges show the information according to their selection. I developed this way because I don't need create many panels and dashboard, it is easy to update and manager.
Problem: When other operator access the app by other browser and select other area, both dashboards change to the same selection. How can I have some variable for each instance (app opened on web browser)?
When the operator select a line and area, has one variable (flow) with this selection, when the dashboard data are updated, the gauges just show the line and area selected.
Hi and welcome to the forum
Client data from the docs may help you. Dashboard 2.0 Sidebar | Node-RED Dashboard 2.0
