All depends what output you require, here are some examples
[{"id":"6e4057f7343692e7","type":"inject","z":"30af2d3e.d94ea2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":60,"wires":[["4214fb45.4b7354"]]},{"id":"4214fb45.4b7354","type":"template","z":"30af2d3e.d94ea2","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<form>\n<text>\n<id>FanLevel</id>\n<value>Nominale</value>\n</text>\n<text>\n<id>VolumenstromZu</id>\n<value>170 m3/h</value>\n</text>\n<text>\n<id>VolumenstromAb</id>\n<value>170 m3/h</value>\n</text>\n<text>\n<id>DrehzahlZu</id>\n<value>1493 rpm</value>\n</text>\n<text>\n<id>DrehzahlAb</id>\n<value>1105 rpm</value>\n</text>\n<text>\n<id>FilterRestGeraet</id>\n<value>0 Jour</value>\n</text>\n<text>\n<id>FilterSchmutzGeraet</id>\n<value>-</value>\n</text>\n<text>\n<id>FilterRestAussen</id>\n<value>-</value>\n</text>\n<text>\n<id>FilterRestRaum</id>\n<value>-</value>\n</text>\n<text>\n<id>SollDruck</id>\n<value>-</value>\n</text>\n<text>\n<id>IstDruck</id>\n<value>-</value>\n</text>\n<text>\n<id>TempRaum</id>\n<value>27.0 °C</value>\n</text>\n<text>\n<id>T_AUL_vor_EWT</id>\n<value>- °C</value>\n</text>\n<text>\n<id>T_Lufteintritt</id>\n<value>24.4 °C</value>\n</text>\n<text>\n<id>T_Zuluft</id>\n<value>24.6 °C</value>\n</text>\n<text>\n<id>T_Abluft</id>\n<value>27.0 °C</value>\n</text>\n<text>\n<id>T_Fortluft</id>\n<value>25.6 °C</value>\n</text>\n<text>\n<id>RfIntern</id>\n<value>49 %</value>\n</text>\n<text>\n<id>Sensor1</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor2</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor3</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor4</id>\n<value>-</value>\n</text>\n<text>\n<id>SensorRfExtern</id>\n<value>0 %</value>\n</text>\n<text>\n<id>SensorLqExtern</id>\n<value>0 ppm</value>\n</text>\n<text>\n<id>Fan_State1</id>\n<value>marche</value>\n</text>\n<text>\n<id>Fan_State2</id>\n<value>marche</value>\n</text>\n<text>\n<id>BypassZustand</id>\n<value>ouvert</value>\n</text>\n<text>\n<id>VhrZustand</id>\n<value>-</value>\n</text>\n<text>\n<id>SchaltBasis</id>\n<value>arrêt</value>\n</text>\n<text>\n<id>ZoneZustand</id>\n<value>-</value>\n</text>\n<text>\n<id>SoleZp1</id>\n<value>-</value>\n</text>\n<text>\n<id>LuftZp1</id>\n<value>-</value>\n</text>\n<text>\n<id>NhrZp1</id>\n<value>-</value>\n</text>\n<text>\n<id>BSTD_FL</id>\n<value>257 h</value>\n</text>\n<text>\n<id>BSTD_RL</id>\n<value>1 h</value>\n</text>\n<text>\n<id>BSTD_NL</id>\n<value>13006 h</value>\n</text>\n<text>\n<id>BSTD_IL</id>\n<value>1496 h</value>\n</text>\n<text>\n<id>BSTD_Luftgesamt</id>\n<value>14760 h</value>\n</text>\n<text>\n<id>BSTD_Schaltkontakt</id>\n<value>0 h</value>\n</text>\n<text>\n<id>BSTD_SoleUwp</id>\n<value>-</value>\n</text>\n<text>\n<id>BSTD_Zone</id>\n<value>-</value>\n</text>\n<text>\n<id>BSTD_LuftEwt</id>\n<value>-</value>\n</text>\n<text>\n<id>BSTD_Nhr</id>\n<value>-</value>\n</text>\n<text>\n<id>SwVersionLT</id>\n<value>1.2.4</value>\n</text>\n<text>\n<id>SwVersionBDE</id>\n<value>-</value>\n</text>\n<text>\n<id>SwVersionSnr</id>\n<value>M202795221JHAZR19417</value>\n</text>\n<text>\n<id>InetDhcp</id>\n<value>Statique</value>\n</text>\n<text>\n<id>InetIp</id>\n<value>192.168.10.210</value>\n</text>\n<text>\n<id>InetSubnet</id>\n<value>255.255.255.0</value>\n</text>\n<text>\n<id>InetGateway</id>\n<value>192.168.10.1</value>\n</text>\n<text>\n<id>InetDns</id>\n<value>192.168.10.1</value>\n</text>\n<text>\n<id>InetStatusServer</id>\n<value>connecté</value>\n</text>\n<text>\n<id>EnOceanDev1</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev2</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev3</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev4</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev5</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev6</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev7</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev8</id>\n<value>-</value>\n</text>\n<text>\n<id>aktuellesDatum</id>\n<value>27.07.2022 11:43</value>\n</text>\n<text>\n<id>Sensor1Typ</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor1Benennung</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor2Typ</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor2Benennung</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor3Typ</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor3Benennung</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor4Typ</id>\n<value>-</value>\n</text>\n<text>\n<id>Sensor4Benennung</id>\n<value>-</value>\n</text>\n<text>\n<id>EnOceanDev1Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n<text>\n<id>EnOceanDev2Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n<text>\n<id>EnOceanDev3Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n<text>\n<id>EnOceanDev4Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n<text>\n<id>EnOceanDev5Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n<text>\n<id>EnOceanDev6Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n<text>\n<id>EnOceanDev7Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n<text>\n<id>EnOceanDev8Value</id>\n<value>Aucune valeur de mesure</value>\n</text>\n</form>","output":"str","x":400,"y":60,"wires":[["39bdcd93b658df8c"]]},{"id":"39bdcd93b658df8c","type":"xml","z":"30af2d3e.d94ea2","name":"","property":"payload","attr":"","chr":".text[11]","x":590,"y":40,"wires":[["e51da240e962975a","18d3af5f.158df1","790cc238.06b2d4"]]},{"id":"e51da240e962975a","type":"debug","z":"30af2d3e.d94ea2","name":"the complete payload","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":760,"y":100,"wires":[]},{"id":"18d3af5f.158df1","type":"change","z":"30af2d3e.d94ea2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.form.text[id[0] = \"TempRaum\"].value.$number($split($,\" \")[0])","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":20,"wires":[["6cbc0bfb.9d17bc"]]},{"id":"790cc238.06b2d4","type":"change","z":"30af2d3e.d94ea2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.form.text[11].value[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":60,"wires":[["526f4675.7627c"]]},{"id":"6cbc0bfb.9d17bc","type":"debug","z":"30af2d3e.d94ea2","name":"value converted to number","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1080,"y":20,"wires":[]},{"id":"526f4675.7627c","type":"debug","z":"30af2d3e.d94ea2","name":"value as is","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1030,"y":60,"wires":[]}]
I put your http request output in a template as others will not have access to your http data, this makes it easier for others to help and test their replies.
