Math formula in Function node for Darkroom Timer Program
I am a newbie to the forums and Node Red too.
I am using Node Red to control my darkroom equipment using 2 remote control sockets. The user inputs a time that triggers a counter, turns the light on and then when the counter ends switches the light off.
I would like to add to the basic functionality by displaying f/stop calculations on the dashboard for information. I need to apply the formula T x 2^+f to the message payload. The value T is the message payload input and f is the stop increase or decrease which will be specified in each function node. An increase of half a stop of light would be T x 2^+0.5
Can anyone assist in helping me for apply the formula in a way that the function node can understand correctly?
Many thanks!
John.
Hi and welcome to the forum.
You may need to clarify the formula as given.
I can't parse that as valid sorry. 2^+f? Is that 2^2+f? (Two squared + f)
Ok, something else. (Not a problem though)
I have written an example flow that shows you how to do this, but you need to understand that the T and f must be sent at the same time - or: in the same message.
So ok: in my example T is defined in the inject node. But at some stage you are going to have to set things up.
If you are wanting T to be the msg.payload it isn't that hard to re-write the code in the function node.
[{"id":"c9949860.264198","type":"function","z":"703c61ac.837e1","name":"","func":"//  T x 2^+f\n\nvar T = parseInt(msg.t);\nvar f = parseInt(msg.f);\n\nvar answer = T * 2^2 + f;\n\nmsg.payload = answer;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1910,"y":540,"wires":[["9626001.13ad18"]]},{"id":"2f36bac6.3f5cf6","type":"inject","z":"703c61ac.837e1","name":"Set T and f","props":[{"p":"T","v":"3","vt":"num"},{"p":"f","v":"5","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":1740,"y":540,"wires":[["c9949860.264198"]]},{"id":"9626001.13ad18","type":"debug","z":"703c61ac.837e1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2080,"y":540,"wires":[]}]
Does that help?
^ is the bitwise XOR operator. The operator to raise to the power of is **
That will be something like
msg.payload = msg.payload * (2**f)
I am never sure of the precedence of ** so I tend to add extra parentheses just in case.
Excellent, thank you for the help. I've got it working as I wanted!
