Merging two data sets with JOIN node
Hi there! I've been trying (unsuccessfully) to merge two data sets using JOIN node using a common key that exists in both sets (msg.name) ... here is what the first data set looks like:
{"ticker":"NASDAQ:WAVE","name":"WAVE","close":10.5,"gap":5.5,"change":20.3,"volume":583738,"relative_volume":5,"relative_volume_10d_calc":8.1,"relative_volume_intraday|5":7.8,"relative_volume_10d_calc|5":2.4,"premarket_change":8.1,"float_shares_outstanding":5326643,"relVol10d|5":241}
here is the second:
{"settlementDate":"2024-09-30","issueName":"Eco Wave Power Global AB (publ","symbolCode":"WAVE","marketClassCode":"SC","currentShortPositionQuantity":"28000","previousShortPositionQuantity":"28653","changePreviousNumber":"-653","changePercent":"-2.28","averageDailyVolumeQuantity":"23647","daysToCoverQuantity":"1.18","revisionFlag":null,"name":"WAVE"}
I've tried every setting in the JOIN mode, the data is not getting merged (in the output I am seeing values from just one of the sets. Thanks in advance!
Each data set needs a different msg.topic.
Set the join node to manual mode, join after 2 messages.
    "dataset1":{
    "dataset2":{
If you give each message the correct msg.parts you can then use a reduced sequence to merge the two messages into one object
e.g.
[{"id":"2fef465e61206fbf","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"parts","v":"{\"id\":\"my_unique_id\",\"type\":\"array\",\"count\":2,\"index\":0}","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"ticker\":\"NASDAQ:WAVE\",\"name\":\"WAVE\",\"close\":10.5,\"gap\":5.5,\"change\":20.3,\"volume\":583738,\"relative_volume\":5,\"relative_volume_10d_calc\":8.1,\"relative_volume_intraday|5\":7.8,\"relative_volume_10d_calc|5\":2.4,\"premarket_change\":8.1,\"float_shares_outstanding\":5326643,\"relVol10d|5\":241}","payloadType":"json","x":90,"y":7740,"wires":[["f735ce51b75bca2b"]]},{"id":"f735ce51b75bca2b","type":"join","z":"d1395164b4eec73e","name":"","mode":"reduce","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"$merge([$A, $$.payload])","reduceInit":"{}","reduceInitType":"json","reduceFixup":"$A","x":290,"y":7760,"wires":[["6c29de9b0257ebe5"]]},{"id":"ea572cdc5ff7ec59","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"parts","v":"{\"id\":\"my_unique_id\",\"type\":\"array\",\"count\":2,\"index\":1}","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"settlementDate\":\"2024-09-30\",\"issueName\":\"Eco Wave Power Global AB (publ\",\"symbolCode\":\"WAVE\",\"marketClassCode\":\"SC\",\"currentShortPositionQuantity\":\"28000\",\"previousShortPositionQuantity\":\"28653\",\"changePreviousNumber\":\"-653\",\"changePercent\":\"-2.28\",\"averageDailyVolumeQuantity\":\"23647\",\"daysToCoverQuantity\":\"1.18\",\"revisionFlag\":null,\"name\":\"WAVE\"}","payloadType":"json","x":90,"y":7780,"wires":[["f735ce51b75bca2b"]]},{"id":"6c29de9b0257ebe5","type":"debug","z":"d1395164b4eec73e","name":"debug 2578","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":610,"y":7760,"wires":[]}]
[edit]
Or use the manual merge with a timeout, or send msg complete with second message
Thanks so much! Spent half a day with ChatGPT trying to solve. ChatGPT did help with a couple of challenges, but couldn't figure out this one :slight_smile:
Actually still a bit of a problem, This worked when I had one record coming from each source ( I filtered "WAVE" out to help with debugging); however when I have a set (sequence of 10 from each) they don't get joined ... should I put some kind of delay/timeout ?
P.S.
Placing a delay node (with rate limit of 1 msg/sec) seemed to work (help). But successful joining seems intermittent (observed even with one record) ... sometimes the two sets get joined, sometimes I see two date sets coming out separately on the output of join node.
Not sure what you are saying as it is a bit vague, example data and flows help here.
Try setting the parts.id to the name property of the incoming objects. failing that provide clear examples.
Turns out there were data mismatches in that field from one of the sources. Ended up doing it a different way (passing one set of data in payload the other in topic). Thanks for your help.
