Message Payload build-up
Hi All,
I'm a bit puzzled.
I've got a device which sends a MQTT message stream. Some values are sent as an object with a value f.i. "temp": 23.2, "hum": 66.6, "Speed status": 44,
when debugging the single values i got stuck on the message "Speed status":44 I cannot view this in the debug window because of the space between Speed and status. How can i solve this?
msg.payload.Speed status does not work because of the space.
Thnx
Hi @ieddev, welcome to the forum.
As you say, msg.payload.Speed status will not work but the alternative format msg.payload["Speed status"] should be OK.
I used msg.payload.["Speed status"] but now i see i was wrong. after losing the dot between payload and [" it works.
thnx
Node-red haa built in tools to help you like the copy path button.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
