Message Properties
Hello community,
I have been working on a project of a my friend. There are several occurings of msg.from and msg.to, but I cannot find it when logging the msg(Json-object). The msg has only been changed/created by a http request. Are those properties linked to the IPs?
Is there a complete list of properties of msg?
Thanks and many regards
Rumei M.
PS: It's my first post on this forum, so if there is any formal mistakes, don't hesitate to tell me :slight_smile:
Hi @Rumei
In a nutshell - no - the msg is what it is & it completely depends what you or a node adds to the message.
If you use a debug node set to show complete message - to see what is in a message.
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
Thank you for the quick reply. After seeing your message I have gone through the whole project again and found where the above mentioned properties are set.
For future reference, if the properties were added by a Change or Function node or by something else explicit in your flows then you could have used the Search feature (Ctrl+F) and searched for from to find it. That would not work if they were added by a node such as the email node for example.
