Helle everyone!
Today I realized that certain options inside the switch node seem to be missing.
An example: The change node has the following options in the dropdown menu: msg.; flow.; global.; String; Number; boolean; JSON; Buffer; timestamp, expression and env variable.
The switch node has less options: menu: msg.; flow.; global.; String; Number; expression; env variable and previous value.
Has anyone an idea why the switch node does not contain for example the boolean option? IMHO a switch according to the value of a boolean variable would make sense in many cases.
