Becker
1
I want to read out some Data from my Inverters (SMA) over modbus tcp, it works but I get a "0" in front of the value:
0, 2695
I only need the second value: 2695 (W).
In a windows app is the same:
+0: 0
+1: the value I need. (in this picture the frequency)
How can I get the second value only ?
greetings
UnborN
2
Hi Becker,
what if you try reading from Address 30776 and Quantity 1
but i guess your result will still be in an array that you can access with msg.payload[0]
Becker
3
Quantity1 will be error, no data
I´ve no idea what Quantity means
UnborN
4
Quantity means how many addresses to read starting from 30775 .. that why you get an array with two elements.
What is the error and what node produces that error ? .. put a debug node after your modbus tcp node with the above configuration.
Becker
5
just disconnect:
the other inverter crashed when I queried more than 4 data.
How can I query the registers one after the other so that the Invert does not crash ?
Becker
6
this is the solution,
function with:
var temp = (msg.payload[1])
msg.payload = temp;
to easy.
