Modbus Flex Write Error
Hi there,
I'm working on a project that involves the Modbus Node.
Since I need to write several coil and register into a modbus server, I used the Modbus-Flex-Write node to collect every "write" message.
Unfortunately, I get this error:
TypeError: Cannot read property 'getMachineState' of undefined
Anybody can help me to understand this error?
I see the modbus queue that grow up because something goes wrong.
Thanks for the help!
Best regards,
Federico
Are you sure it is coming from the modbus node?
Yes it comes from Modbus Write Node
I don't know what does it means, it seems something related to the server status.
From the catch node, I get this output
TypeError: Cannot read property 'getMachineState' of undefined at Object._inputCallback (/opt/node-red/node_modules/node-red-contrib-modbus/modbus/maps/modbus-flex-write.js:52:5) at Object.Node._emitInput (/opt/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:199:18) at Immediate._onImmediate (/opt/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:179:33) at processImmediate (internal/timers.js:439:21)
Any ideas?
Thank you
What version of node-red and nodejs are you using. For the latter, use
node -v
If that is V12, 14, or 16 then that should be ok. If you are using a recent version of node red then probably best to post an issue on the node's GitHub page.
My node-red version in "1.0.3: Maintenance Release"
This is an industrial device an I cannot access to command line to get the nodej version.
This kind of error could be related to the modbus server that does not offer the missing properties?
Put an issue on the node's GitHub page, I think only the author can answer this.
