Hi all,
I have a flow trying to get some Modbus readings. I have 2 modbus devices, one of which seems to work fine. The other one is intermittent and fails most of the time. Can anyone tell me what this error message means and what to do about it?
- Error: FSM Not Ready To Read At State INIT
[{"id":"864f82e3.64c7e","type":"tab","label":"SI6 Modbus","disabled":false,"info":""},{"id":"21eec4d6.8d0f8c","type":"debug","z":"864f82e3.64c7e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":610,"y":100,"wires":[]},{"id":"3f0d89a7.eb4176","type":"modbus-read","z":"864f82e3.64c7e","name":"SI6 Battery Voltage","topic":"SI6 Battery Voltage","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"3","dataType":"HoldingRegister","adr":"30851","quantity":"2","rate":"2","rateUnit":"s","delayOnStart":true,"startDelayTime":"5","server":"933ad670.8b8e58","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":170,"y":140,"wires":[["490ee8b0.924658","2614ce9.c1cc932"],[]]},{"id":"490ee8b0.924658","type":"function","z":"864f82e3.64c7e","name":"SMA Battery Voltage","func":"var msg1 = { payload:\"output\" };\nvar voltage = parseInt(msg.payload[1]);\nmsg1.payload = voltage.toString();\n\nreturn msg1;","outputs":1,"noerr":0,"x":420,"y":140,"wires":[["21eec4d6.8d0f8c"]]},{"id":"2614ce9.c1cc932","type":"debug","z":"864f82e3.64c7e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":570,"y":60,"wires":[]},{"id":"933ad670.8b8e58","type":"modbus-client","z":"","name":"SI6","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"192.168.1.22","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"3","commandDelay":"1","clientTimeout":"1000","reconnectTimeout":"2000"}]
