maybe NODE-red has no access to your usb/com port where i believe your device is connected to, You mentioned usb-rs485 adapter connected direct to meter right, you proved that your connection is right with modscan, was such setup ever worked for you with diff device before? be sure that nothing ele is using this com port while you deploy node-red flow
Yes you are correct. I think i have issues with my node red. i will try uninstall install node red again
hi...
how about the progress? still not working? maybe i can share my modbus rtu node for your reference
Though i have uninstalled and installed i got no success
nodejs version:
and with this flow json
[{"id":"582f1736.87a998","type":"modbus-getter","z":"77e78410.d9584c","name":"","showStatusActivities":true,"showErrors":true,"logIOActivities":false,"unitid":"40","dataType":"HoldingRegister","adr":"15019","quantity":"2","server":"d44638ff.6e6458","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":900,"y":660,"wires":[["f1eb0b8f.50bd58"],["cfc300f2.8b8aa"]]},{"id":"e8c6b3cc.59875","type":"inject","z":"77e78410.d9584c","name":"30s","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"1","x":730,"y":660,"wires":[["582f1736.87a998"]]},{"id":"f1eb0b8f.50bd58","type":"debug","z":"77e78410.d9584c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1090,"y":640,"wires":[]},{"id":"cfc300f2.8b8aa","type":"debug","z":"77e78410.d9584c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1090,"y":680,"wires":[]},{"id":"d44638ff.6e6458","type":"modbus-client","z":"","name":"USB1","clienttype":"serial","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB1","serialType":"RTU-BUFFERD","serialBaudrate":"19200","serialDatabits":"8","serialStopbits":"1","serialParity":"even","serialConnectionDelay":"5","unit_id":"","commandDelay":200,"clientTimeout":300,"reconnectTimeout":5}]
can you try to read full block of registers not just 1 or 2 from i.e. power table but all ?
