Modbus RTU node red UART issue
Hello Colin,
Basically, Node-red is perfectly running my Modbus TCP node is also working perfectly, but the only issue is with the Serial UART interface. I have seen this kind of issue many developers are facing, with this same error/problem.
you can refer this kind of issue - Segment fault error occurs when deploy node-red-node-serial in openWRT
for this, I am able to use a Simple Serial interface node node-red-node-serialport@0.15.0 version, without any issue. But my problem is with Modbus RTU serial UART node i am facing this issue.
In case you need any further information from my side please let me know.
Br,
Devendra
