I am trying to communicate Modbus TCP node with Modscan ,
Can you please help me in this regards?
I am putting Modbus TCP IP arress as 192.168.0.100 in ndeRED for my device & trying to connect Modscan with 192.168.0.150....but not communicating
BR
Madhumati
Which Modbus node have you installed? node-red-contrib-.....?
What version of Node-RED and nodejs are you running ( both listed when you startup Node-RED)
What is running on 192.168.0.150?
Node-REd version - 0.18.7
node-red-contrib-modbus@2.3.2-r0
There is PC iwth Modscan installed having 192.168.0.150, I am nt sure if I can communicate this node with Modscan software?
BR
Madhumati
What version of nodejs? Any reason your version of Node-RED and the contrib node you are using is so far behind the current versions?
Thanks I am able to test it with Modsim i.e Modbus TCP serevr ..........but still struggeling with Modscan Modbus TCP client...I will update shortly
BR
Madhumati
