ModBus TCP Read 32-bit registers
I am using a Siemens PAC 2200 device that reads information from the mains such as voltage, current, etc. The manual for this device tells you the registers sent by MODBUS, some of them Float type and some Double type. Float-type ones I can read quietly. But the Double type I can not. Following are some images to better exemplify.
nodered PAC2200 The nod-red image I get an array of 4 values, and I need to turn this value into real information, as you can see in the other figure.
Does @thatcadguy's idea work?
As far as I can see from an internal document the PAC2200 power meter features the same registers for Modbus as the PAC3200. Because there were and are still problems with supporting 64bit floatsn many data acquisition packages they created an new set of 32 bit floats for the Energy values. I don't have a PAC2200 on hand to verify this but in the PAC3200 the attached registers are used. A simple test should allow to verify if they are present in the PAC2200 in case you want to avoid the 64bit conversion .
Capture
Dear iridiu,
we are also using the teltonika rut955 and i have to cellect data from the router.
I saw you did a great job with node-red an i want to ask you if you could share/post your final flow on this platform. I think some people would be very happy about that!
THX!
Christian
Hi c.hinterdorfer,
This is a working flow for Teltonika RUT240 wich is very similar to RUT955, and is a starting point.
To read GPS data from RUT955 was very hard... And I had an AVL parser/decoder in Node-Red, but now you can read that info with Modbus TCP :slight_smile:
I'm sure you can adapt this flow for RUT955.
[{"id":"81879cd5.08b26","type":"function","z":"fca65c59.c8674","name":"Current SIM card","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString('ascii');\n    \n// Save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":206,"wires":[["1eb738c8.26c067"]]},{"id":"6fd38a1f.6f58c4","type":"function","z":"fca65c59.c8674","name":"System uptime","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value;\nreturn msg;","outputs":1,"noerr":0,"x":540,"y":86,"wires":[["ac5bbac5.d986b8"]]},{"id":"56672571.1021ec","type":"function","z":"fca65c59.c8674","name":"GSM signal strength (dBm)","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":126,"wires":[["f579b6c1.a96f98"]]},{"id":"c3d1adf5.066af","type":"function","z":"fca65c59.c8674","name":"GSM operator name","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString('ascii');\n    \n// Save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":166,"wires":[["886c0b7d.ffaa38"]]},{"id":"f579b6c1.a96f98","type":"ui_gauge","z":"fca65c59.c8674","name":"","group":"334e1001.37fb2","order":0,"width":0,"height":0,"gtype":"gage","title":"Signal strength","label":"dBm","format":"{{value}}","min":"-100","max":"0","colors":["#ff0000","#ffff00","#00ff00"],"seg1":"-90","seg2":"-70","x":1080,"y":126,"wires":[]},{"id":"886c0b7d.ffaa38","type":"ui_text","z":"fca65c59.c8674","group":"334e1001.37fb2","order":0,"width":0,"height":0,"name":"","label":"Operator GSM","format":"{{msg.payload}}","layout":"row-spread","x":1080,"y":166,"wires":[]},{"id":"1eb738c8.26c067","type":"ui_text","z":"fca65c59.c8674","group":"334e1001.37fb2","order":0,"width":0,"height":0,"name":"","label":"Current SIM card","format":"{{msg.payload}}","layout":"row-spread","x":1070,"y":206,"wires":[]},{"id":"105c5b0d.fdeb55","type":"function","z":"fca65c59.c8674","name":"Network registration","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString('ascii');\n    \n// Save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":246,"wires":[["992e192f.f1cd08"]]},{"id":"992e192f.f1cd08","type":"ui_text","z":"fca65c59.c8674","group":"334e1001.37fb2","order":0,"width":0,"height":0,"name":"","label":"Registration","format":"{{msg.payload}}","layout":"row-spread","x":1090,"y":246,"wires":[]},{"id":"d83b34a2.ba28f8","type":"function","z":"fca65c59.c8674","name":"Network type","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString('ascii');\n    \n// Save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":286,"wires":[["6470684b.665a88"]]},{"id":"6470684b.665a88","type":"ui_text","z":"fca65c59.c8674","group":"334e1001.37fb2","order":0,"width":0,"height":0,"name":"","label":"Network type","format":"{{msg.payload}}","layout":"row-spread","x":1090,"y":286,"wires":[]},{"id":"783cad89.772204","type":"function","z":"fca65c59.c8674","name":"System temperature in 0.1 degrees Celcius","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value/10;\n\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":326,"wires":[["63b5ab00.8f0c54"]]},{"id":"63b5ab00.8f0c54","type":"ui_gauge","z":"fca65c59.c8674","name":"","group":"9eeaabd2.5bcc98","order":1,"width":0,"height":0,"gtype":"gage","title":"Temp","label":"°C","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1110,"y":326,"wires":[]},{"id":"a3b31b70.d07098","type":"function","z":"fca65c59.c8674","name":"System hostname","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString(\"ascii\");\n\n\n// Save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":366,"wires":[["5230319f.5ef13"]]},{"id":"4a006b14.c374f4","type":"function","z":"fca65c59.c8674","name":"Router serial number","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString('ascii');\n    \n// Save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":406,"wires":[["2798e42e.6d785c"]]},{"id":"55aa0978.dc7198","type":"function","z":"fca65c59.c8674","name":"Router MAC address","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString('ascii');\n    \n// Save the value\n//msg.payload = value;\nmsg.payload = value.match(/.{2}/g).join(':').slice(0, 17);\n\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":446,"wires":[["b688b183.874d1"]]},{"id":"61dcf0fd.8b5db","type":"function","z":"fca65c59.c8674","name":"Router name","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Convert bytes to string\nconst value = buf.toString('ascii');\n    \n// Save the value\nmsg.payload = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":486,"wires":[["4c2b2bbb.2a4234"]]},{"id":"508e84ca.a0404c","type":"ui_text","z":"fca65c59.c8674","group":"9eeaabd2.5bcc98","order":2,"width":0,"height":0,"name":"","label":"Hostname","format":"{{msg.payload}}","layout":"row-spread","x":1090,"y":366,"wires":[]},{"id":"2798e42e.6d785c","type":"ui_text","z":"fca65c59.c8674","group":"9eeaabd2.5bcc98","order":3,"width":0,"height":0,"name":"","label":"Serial number","format":"{{msg.payload}}","layout":"row-spread","x":1080,"y":406,"wires":[]},{"id":"b688b183.874d1","type":"ui_text","z":"fca65c59.c8674","group":"9eeaabd2.5bcc98","order":4,"width":0,"height":0,"name":"","label":"Mac address","format":"{{msg.payload}}","layout":"row-spread","x":1090,"y":446,"wires":[]},{"id":"4c2b2bbb.2a4234","type":"ui_text","z":"fca65c59.c8674","group":"9eeaabd2.5bcc98","order":5,"width":0,"height":0,"name":"","label":"Router name","format":"{{msg.payload}}","layout":"row-spread","x":1090,"y":486,"wires":[]},{"id":"a0f4c0b5.0d5ad","type":"ui_text","z":"fca65c59.c8674","group":"9eeaabd2.5bcc98","order":6,"width":0,"height":0,"name":"","label":"WAN IP","format":"{{value}}","layout":"row-spread","x":1100,"y":526,"wires":[]},{"id":"d941066b.63f538","type":"function","z":"fca65c59.c8674","name":"Converttoip","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\nconst value1 = buf.readUInt8(0);\nconst value2 = buf.readUInt8(1);\nconst value3 = buf.readUInt8(2);\nconst value4 = buf.readUInt8(3);\n\nmsg.payload = value1 + \".\" + value2 + \".\" +value3 + \".\" +value4;\nglobal.set(\"WAN_IP\", msg.payload);\n//msg.payload = [value1, value2, value3, value4];\n\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":526,"wires":[["a0f4c0b5.0d5ad"]]},{"id":"17d82add.c3c9a5","type":"ui_text","z":"fca65c59.c8674","group":"9eeaabd2.5bcc98","order":9,"width":0,"height":0,"name":"","label":"Uptime","format":"{{msg.payload | date:\"dd  HH:mm:ss\"}}","layout":"row-spread","x":1100,"y":86,"wires":[]},{"id":"ac5bbac5.d986b8","type":"function","z":"fca65c59.c8674","name":"Uptime DD:HH:MM:SS","func":"var seconds = parseInt(msg.payload, 10);\n\nvar days = Math.floor(seconds / (3600*24));\nseconds  -= days*3600*24;\nvar hrs   = Math.floor(seconds / 3600);\nseconds  -= hrs*3600;\nvar mnts = Math.floor(seconds / 60);\nseconds  -= mnts*60;\nresult = (days+\" D, \"+hrs+\" H, \"+mnts+\" M, \"+seconds+\" S\");\n msg.payload=result;\n return msg;","outputs":1,"noerr":0,"x":800,"y":80,"wires":[["17d82add.c3c9a5"]]},{"id":"5230319f.5ef13","type":"function","z":"fca65c59.c8674","name":"Global Set","func":"global.set(\"HOOSUnit\", msg.payload.replace(/\\W+/g,\"\"));\nreturn msg;","outputs":1,"noerr":0,"x":810,"y":366,"wires":[["508e84ca.a0404c"]]},{"id":"7ac992f2.d1aafc","type":"ui_text","z":"fca65c59.c8674","group":"2ef27044.98bde","order":1,"width":0,"height":0,"name":"","label":"Received today","format":"{{value | number:2}} MB","layout":"row-spread","x":1080,"y":680,"wires":[]},{"id":"801123c9.52d64","type":"function","z":"fca65c59.c8674","name":"Received today","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value * 1000 / 1000000;\n\nreturn msg;","outputs":1,"noerr":0,"x":540,"y":680,"wires":[["7ac992f2.d1aafc"]]},{"id":"4c373021.b1cc3","type":"comment","z":"fca65c59.c8674","name":"Mobile data","info":"All received/sent data usage values are returned in kibibytes (KiB), which is an ISQ standard accepted by most major standard organizations. \n1 kibibyte (KiB) = 210 bytes = 1024 bytes \n1 mebibyte (MiB) = 210 kibibytes (KiB) = 220 bytes = 1 048 576 bytes","x":170,"y":620,"wires":[]},{"id":"4a2681b5.47657","type":"ui_text","z":"fca65c59.c8674","group":"2ef27044.98bde","order":2,"width":0,"height":0,"name":"","label":"Sent today","format":"{{value | number:2}} MB","layout":"row-spread","x":1070,"y":720,"wires":[]},{"id":"b81bc57c.5cd418","type":"function","z":"fca65c59.c8674","name":"Mobile data sent today","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value * 1024 / 1048576;\n\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":720,"wires":[["4a2681b5.47657"]]},{"id":"232b378e.936748","type":"ui_text","z":"fca65c59.c8674","group":"2ef27044.98bde","order":4,"width":0,"height":0,"name":"","label":"Received this week","format":"{{value | number:2}} MB","layout":"row-spread","x":1090,"y":760,"wires":[]},{"id":"7e133402.29d83c","type":"function","z":"fca65c59.c8674","name":"Mobile data received this week","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value * 1024 / 1048576;\n\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":760,"wires":[["232b378e.936748"]]},{"id":"b4abb5ba.71d828","type":"ui_text","z":"fca65c59.c8674","group":"2ef27044.98bde","order":5,"width":0,"height":0,"name":"","label":"Sent this week","format":"{{value | number:2}} MB","layout":"row-spread","x":1080,"y":800,"wires":[]},{"id":"cb095ed0.47934","type":"function","z":"fca65c59.c8674","name":"Mobile data sent this week","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value * 1024 / 1048576;\n\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":800,"wires":[["b4abb5ba.71d828"]]},{"id":"2aba9fae.8e21","type":"ui_text","z":"fca65c59.c8674","group":"2ef27044.98bde","order":7,"width":0,"height":0,"name":"","label":"Received this month","format":"{{value | number:2}} MB","layout":"row-spread","x":1100,"y":840,"wires":[]},{"id":"69e18ce8.ffbcd4","type":"function","z":"fca65c59.c8674","name":"Mobile data received this month","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value * 1024 / 1048576;\n\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":840,"wires":[["2aba9fae.8e21"]]},{"id":"15df397c.2219c7","type":"ui_text","z":"fca65c59.c8674","group":"2ef27044.98bde","order":8,"width":0,"height":0,"name":"","label":"Sent this month","format":"{{value | number:2}} MB","layout":"row-spread","x":1080,"y":880,"wires":[]},{"id":"a5f2bbd.406cc48","type":"function","z":"fca65c59.c8674","name":"Mobile data sent this month","func":"// Create new Buffer based on array bytes\nconst buf = Buffer.from(msg.payload.buffer);\n\n// Represent these bytes as 32-bit unsigned int\nconst value = buf.readInt32BE();\n\n// save the value\nmsg.payload = value * 1024 / 1048576;\n\nreturn msg;","outputs":1,"noerr":0,"x":580,"y":880,"wires":[["15df397c.2219c7"]]},{"id":"cab23fc4.7d451","type":"modbus-read","z":"fca65c59.c8674","name":"System uptime","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"1","quantity":"2","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":200,"y":80,"wires":[[],["6fd38a1f.6f58c4"]]},{"id":"b1df2865.d96108","type":"modbus-read","z":"fca65c59.c8674","name":"GSM signal strength (dBm)","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"3","quantity":"2","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":230,"y":120,"wires":[[],["56672571.1021ec"]]},{"id":"5f409a48.fc2044","type":"modbus-read","z":"fca65c59.c8674","name":"System temperature in 0.1 degrees Celcius","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"5","quantity":"2","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":280,"y":321,"wires":[[],["783cad89.772204"]]},{"id":"794a5b30.31f254","type":"modbus-read","z":"fca65c59.c8674","name":"System hostname","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"7","quantity":"16","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":210,"y":360,"wires":[[],["a3b31b70.d07098"]]},{"id":"27756803.d7ff88","type":"modbus-read","z":"fca65c59.c8674","name":"GSM operator name","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"23","quantity":"16","rate":"1","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":210,"y":160,"wires":[[],["c3d1adf5.066af"]]},{"id":"b14c1bdf.34c3a8","type":"modbus-read","z":"fca65c59.c8674","name":"Router serial number","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"39","quantity":"16","rate":"1","rateUnit":"m","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":220,"y":400,"wires":[[],["4a006b14.c374f4"]]},{"id":"a97fd3a.52f3a3","type":"modbus-read","z":"fca65c59.c8674","name":"Router MAC address","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"55","quantity":"16","rate":"1","rateUnit":"m","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":220,"y":440,"wires":[[],["55aa0978.dc7198"]]},{"id":"ec6504af.911a38","type":"modbus-read","z":"fca65c59.c8674","name":"Router name","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"71","quantity":"16","rate":"30","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":190,"y":482,"wires":[[],["61dcf0fd.8b5db"]]},{"id":"70ba652d.21258c","type":"modbus-read","z":"fca65c59.c8674","name":"Current SIM card","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"87","quantity":"16","rate":"10","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":200,"y":200,"wires":[[],["81879cd5.08b26"]]},{"id":"132d0f20.d114c1","type":"modbus-read","z":"fca65c59.c8674","name":"Network registration","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"103","quantity":"16","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":210,"y":240,"wires":[[],["105c5b0d.fdeb55"]]},{"id":"65aa8a0d.15f954","type":"modbus-read","z":"fca65c59.c8674","name":"Network type","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"119","quantity":"16","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":190,"y":280,"wires":[[],["d83b34a2.ba28f8"]]},{"id":"58750c5e.8cef14","type":"modbus-read","z":"fca65c59.c8674","name":"Current WAN IP address","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"139","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":230,"y":520,"wires":[[],["d941066b.63f538"]]},{"id":"dc593c4d.27873","type":"modbus-read","z":"fca65c59.c8674","name":"Mobile data received today","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"135","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":230,"y":680,"wires":[[],["801123c9.52d64"]]},{"id":"5debc960.4ffd78","type":"modbus-read","z":"fca65c59.c8674","name":"Mobile data sent today","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"137","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":220,"y":720,"wires":[[],["b81bc57c.5cd418"]]},{"id":"17abf496.10073b","type":"modbus-read","z":"fca65c59.c8674","name":"Mobile data received this week","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"141","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":250,"y":760,"wires":[[],["7e133402.29d83c"]]},{"id":"376fd292.629c5e","type":"modbus-read","z":"fca65c59.c8674","name":"Mobile data sent this week","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"143","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":230,"y":800,"wires":[[],["cb095ed0.47934"]]},{"id":"c1a51d06.3abac","type":"modbus-read","z":"fca65c59.c8674","name":"Mobile data received this month","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"145","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":250,"y":840,"wires":[[],["69e18ce8.ffbcd4"]]},{"id":"2505e075.e6f5","type":"modbus-read","z":"fca65c59.c8674","name":"Mobile data sent this month","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"","dataType":"HoldingRegister","adr":"147","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"4bf39c08.be3624","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":240,"y":880,"wires":[[],["a5f2bbd.406cc48"]]},{"id":"334e1001.37fb2","type":"ui_group","z":"","name":"GSM network","tab":"566d2cfc.c12004","order":1,"disp":true,"width":"6","collapse":false},{"id":"9eeaabd2.5bcc98","type":"ui_group","z":"","name":"Router","tab":"566d2cfc.c12004","order":2,"disp":true,"width":"6","collapse":false},{"id":"2ef27044.98bde","type":"ui_group","z":"","name":"Data usage","tab":"566d2cfc.c12004","order":3,"disp":true,"width":"6","collapse":false},{"id":"4bf39c08.be3624","type":"modbus-client","z":"","name":"Router","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"tcpHost":"192.168.1.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectTimeout":"2000"},{"id":"566d2cfc.c12004","type":"ui_tab","z":"","name":"Router","icon":"router","order":5,"disabled":false,"hidden":false}]
Hi iridiu,
Thanks a lot for your help!!!
Regards!
