modbusRTU over RS485: Port Not Option
This seems to be a re-occurring problem with these nodes and reading through several of the topics (including my previous one).
This time I'm trying to connect to a serial device. It was working on a Tulip Edge IO device using their ancient Node Red 1.3.5. At some point node-red-contrib-modus was updated to no longer be compatible with 1.X so I put Fedora Linux on a tablet and installed Node Red 3.0.2 (and the latest node-red-contrib-modbus).
Using a catch node I can get the following very unhelpful error:
Error: Port Not Open
    at /home/nodered/.node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
Looking at line 79 of the file on github seems to be for closing the port. So am I to assume it's trying to close a port that's not open?
Furthermore, the documentation for node-red-contrib-modbus is very confusing. At the top it says it's BASED on modbus-serial, but in the details says to test using modbus-serial if you have issues.
Which I did with what I think is success. I don't have the controller I'm trying to talk to while I'm troubleshooting in the lab but I can see the TX light blink on the USB->RS485 adapter when I run the following script and do not see a blink when I click the inject node in NR.
$ cat modbus-test.js
const ModbusRTU = require('modbus-serial');
const client = new ModbusRTU();
client.connectRTUBuffered('/dev/ttyUSB0', { baudRate: 19200 }, (err) => {
  if (err) {
    console.error(err);
    return;
  client.setID(1); // Modbus slave address
  client.setTimeout(500);
  const start = 2000; // starting register address
  const quantity = 10; // number of registers to read
  client.readHoldingRegisters(start, quantity)
    .then((data) => {
      console.log(data); // do something with the received data
    .catch((err) => {
      console.error(err); // handle error
    .finally(() => {
      client.close(); // close connection after the operation is complete
For posterity here's the flow:
:face_with_symbols_over_mouth: :face_with_symbols_over_mouth: :face_with_symbols_over_mouth:
I had COMPLETELY FORGOTTEN that by default the installer creates a nodered user rather than install as the current user.
Added nodered to the dialout group and now it can open the port!
Which installer is that?
Which one of those?
Sorry, had to be quick as I had a meeting to get to...
The RPM method (Since it's Fedora Linux).
Looks like it's related to this commit:
It changed a little over a year ago but I haven't used it on a fresh install in a while.
OK, that appears to be specific to the rpm version. I wonder why that was done.
I don't think it's necessarily a bad idea. Flowforge does the same thing, but some reminders about WHO needs to be in the dialout group would be good. :slight_smile:
