Modify JSON property to include additional text -maybe using regex?
I have some JSON that looks like the following:
        "StationNum": 32109,
        "Height": 3.686
        "StationNum": 32152,
        "Height": 1.598
        "StationNum": 32155,
        "Height": 1.768
        "StationNum": 32167,
        "Height": 3.527
Is there a way to use the StationNum with something like regex and change it to be more like the following. Note that I've added text either side of the number:
        "StationNum": "G_32109_Height",
        "Height": 3.686
        "StationNum": "G_32152_Height",
        "Height": 1.598
        "StationNum": "G_32155_Height",
        "Height": 1.768
        "StationNum": "G_32167_Height",
        "Height": 3.527
Regex for matching the StationNum is (I believe): (\s[0-9]{5,7})+. What I'm stuck with, is if I can use this in a replace.
Your object is not valid is it supposed to be an array of objects.
If so the expresion to transfrom the stationNum would be
$$.payload ~> |$|{"StationNum": "G_" & StationNum & "_Height"}|
Input
            "Height": 3.686
            "Height": 1.598
            "Height": 1.768
            "Height": 3.527
Output
        "Height": 3.686
        "Height": 1.598
        "Height": 1.768
        "Height": 3.527
Thank you very much!
