Modifying json outputs in Node-RED flows
Dear expert and more experienced coders,
I am trying to edit the MQTT-out of a new set of flows (set2) to basically follow the MQTT-out nodes of an existing set of flows (set1) so that the data from set2 could be uploaded to the same platform with a similar json string format.
In set1, the sensor data are extracted via OPC-UA servers, get converted from Boolean to int (1 or 0) and then put into a "msg.payload" json string as follows, for example:
msg.payload = {"id" : "4", "version": "1.0", "params": [{"deviceKey": "aBCdeFgHi", "measurepoints": {"sensor_object_present": msg.payload }, "time": Time}],"method": "integration.measurepoint.post"}
In set2, the different types of data are extracted individually from a SICK device (TDC-E) via http://hwmanager:8000/api/v1/device-info/AvailableMemory and then sent to Node-RED dashboard after formatting as follows, for example:
var AvailableMemory = msg.payload;
msg.payload = AvailableMemory;
//Write NODE status
node.status({ fill: "green", shape: "ring", text: "AvailableMemory: " + AvailableMemory + ""});
//Return message
There is also an overall device-info node which extract all the sensor data, format them as follows and then send MQTT message to 192.168.0.100:9000 (the TDC-E router) or 194.152.206.247:1883 (according to the Node-RED example for TDC-E document).
// create new date object. (includes current time)
var now = new Date();
// convert current time to ISO format
//now.toISOString()
// Basic topic for TDC-E meta data
msg.topic = "VD0B8050E8D05CEA581E/S/";
if (msg.payload !== null && msg.payload !== '' ) {
    return [{ "payload": now.toISOString() + "|" + msg.payload.DeviceName + "|h|7",
              "topic":msg.topic+"TDC_E_DeviceName"
            { "payload": now.toISOString() + "|" + msg.payload.ProductNumber + "|h|7",
              "topic":msg.topic+"TDC_E_ProductNumber"
            { "payload": now.toISOString() + "|" + msg.payload.SerialNumber + "|h|7",
              "topic":msg.topic+"TDC_E_SerialNumber"
            { "payload": now.toISOString() + "|" + msg.payload.IMEI + "|h|7",
              "topic":msg.topic+"TDC_E_IMEI"
            { "payload": now.toISOString() + "|" + msg.payload.SystemVersion + "|h|7",
              "topic":msg.topic+"TDC_E_SystemVersion"
            { "payload": now.toISOString() + "|" + msg.payload.AvailableMemory + "|h|7",
              "topic":msg.topic+"TDC_E_AvailableMemory"
            { "payload": now.toISOString() + "|" + msg.payload.Cpu + "|h|7",
              "topic":msg.topic+"TDC_E_Cpu"
            { "payload": now.toISOString() + "|" + msg.payload.EnvironmentTemperature + "|h|7",
              "topic":msg.topic+"TDC_E_ET"
} else {
    // ERROR
    // handle if variable could not be received
    node.warn("Error, receiving picoStratus value.");
A few questions:
  1. What could be the purpose of this Send MQTT Message node?
  2. How do I create a json string similar to that in set1 while keeping the existing json string? (Note: While the variable name is like "AvailableMemory", the same variable in the MQTT-out string is like "TDC_E_AvailableMemory".)
Many thanks for your help in advance.
A beginner Node-RED coder
Jo Tan
Admin edit - change block quotes to code blocks
Hi Jo, welcome to the forum. Please use the CODE button not the QUOTE button for code
You dont. You create a JavaScript object & when it is transmitted to MQTT it is converted to JSON automatically.
e.g. creating JSON - ugly mess & hard to understand...
msg.payload = "{ \"value\": \"" + msg.payload + "\" }";
e.g. creating the save value as a JS Object...
msg.payload = {
  "value":  msg.payload
So if you want to format data set2 into the same format as data set1 then something like...
msg.payload = {
  "id" : "4",  //<<set this to the value from your set2 data
  "version": "1.0",  //<<set this to the value from your set2 data
  "params": [
      "deviceKey": "aBCdeFgHi",  //<<set this to the value from your set2 data
      "measurepoints": {
        "sensor_object_present": msg.payload  //<< set this to the value from your set2 data
      "time":  Time
  "method": "integration.measurepoint.post" //<<set this to the value from your set2 data
Thank you for the welcome. Noted about the CODE button.
Thank you, Steve, for your replies. Noted about your point wrt the messiness of json and of a Javascript object being converted to json once transmitted to MQTT.
Perhaps I didn't phrase my questions clearly enough.
I am confused by how the msg.payload in set2 concatenates now.toISOString(), a "|", variable name (e.g. AvailableMemory, "|h|7", "topic":msg.topic+"TDC_E_AvailableMemory".
And uncertain as to how to string it as
msg.payload = {"id" : "4", "version": "1.0", "params": [{"deviceKey": "aBCdeFgHi", "measurepoints": {"TDC_E_AvailableMemory": msg.payload }, "time": Time}],"method": "integration.measurepoint.post"}
A sticking point is that there are two variables used in set2: AvailableMemory and TDC_E_AvailableMemory (the one that I need for MQTT-out),
Another sticking point is that set2 seems to extract the device info twice: first individually and then collectively. Hmm... Perhaps the individual extraction is merely to output to the dashboard, and the collective extraction is for MQTT-out to 194.152.206.247:1833 (which seems to be an Aedes broker).
One more sticking point: set2 uses payload for each measurement point while set1 uses params for the device key and all the measurement points.
So if I want to convert set2 to set1 data structure, could I simply ignore the individual extractions and just modify the MQTT-out node to the online platform that we are using for set1? Or add a new MQTT-out node? Or...
