Can you add debug nodes to the outputs of the mongo nodes, set to Output Complete Message, and capture the output and paste it here so I can simulate the flow. This canned text explains how to copy output from the debug window in a way that can be copied and used in a flow:
Also, in future, if posting a flow, code or data, rather than attaching a file, please use the method explained in this canned text:
code goes here
