I am using node-red version 2.2.2 and node.js version 12.22.8. This instance was deployed in rancher kubernetes management platform. When I use nodered v2.2.2 inject node and debug nodes are enabled but debug outputs are not showing in the the panel but I get successfully injected message. I also tried upgrading to nodered version 3.0.2 In that inject nodes and debug nodes cannot be enabled. What can be the reason for this any fix?, I tried npm update but it didn't fix the issue.
With node-red 3.0.2 start node red in a command window and post the startup log here.
it is likely you have an issue in your flows or a contrib node preventing the flows from starting on the server.
the second common reason is that websockets are blocked.
Check the browsers dev tools -> network tab for any rad requests.
And as @Colin said - post your startup log.
And one additional question - where/how are you running node-red - docker? nas? rasp pi? windows? etc etc
Thank you for replying. Forum shows that new users cant upload attachments, so please find part of the log below.
31 Jul 09:55:05 - [warn] [node-red-contrib-mongodb4/mongodb4] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/mongodb/lib/bson.js
- /data/node_modules/mongodb/lib/utils.js
- /data/node_modules/mongodb/lib/operations/add_user.js
- /data/node_modules/mongodb/lib/admin.js
- /data/node_modules/mongodb/lib/index.js
- /data/node_modules/node-red-contrib-mongodb4/src/mongodb4.js
- /usr/src/node-red/node_modules/@node-red/registry/lib/loader.js
- /usr/src/node-red/node_modules/@node-red/registry/lib/index.js
- /usr/src/node-red/node_modules/@node-red/runtime/lib/nodes/index.js
- /usr/src/node-red/node_modules/@node-red/runtime/lib/index.js
- /usr/src/node-red/node_modules/node-red/lib/red.js
- /usr/src/node-red/node_modules/node-red/red.js
31 Jul 09:55:05 - [warn] ------------------------------------------------------
31 Jul 09:55:05 - [info] Settings file : /data/settings.js
31 Jul 09:55:05 - [info] Context store : 'default' [module=memory]
31 Jul 09:55:05 - [info] User directory : /data
31 Jul 09:55:05 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Jul 09:55:05 - [info] Flows file : /data/flows.json
31 Jul 09:55:05 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
31 Jul 09:55:05 - [info] Starting flows
31 Jul 09:55:05 - [info] Started flows
31 Jul 09:59:37 - [info] Stopping flows
31 Jul 09:59:37 - [info] Stopped flows
31 Jul 09:59:37 - [info] Updated flows
31 Jul 09:59:37 - [info] Starting flows
31 Jul 09:59:37 - [info] Started flows
In the browser developer options network shows following error also
Firefox can’t establish a connection to the server at wss://nodered-dashboard.test.lk/comms.
Thank you.
Please post the start of the log up to the error. Pasting it in is the correct way to do it.
You didn't answer all of @Steve-Mcl's questions - in particular whether it is a docker install.
The node showing the error has not installed correctly, so I suggest you try installing that again.
Hi, Please find the full log.
31 Jul 09:55:04 - [info]
Welcome to Node-RED
31 Jul 09:55:04 - [info] Node-RED version: v3.0.2
31 Jul 09:55:04 - [info] Node.js version: v16.20.1
31 Jul 09:55:04 - [info] Linux 3.10.0-1160.el7.x86_64 x64 LE
31 Jul 09:55:05 - [info] Loading palette nodes
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Client] Error: Cannot find module '@xstate/fsm'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/core/modbus-client-core.js
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-client.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Read] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/core/modbus-core.js
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-read.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Getter] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-getter.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Flex-Getter] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-flex-getter.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Write] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-write.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Flex-Write] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-flex-write.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Server] Error: Cannot find module 'jsmodbus'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-server.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Flex-Server] Error: Cannot find module '@serialport/parser-byte-length'
Require stack:
- /data/node_modules/serialport/dist/index.js
- /data/node_modules/modbus-serial/index.js
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-flex-server.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Queue-Info] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/core/modbus-queue-core.js
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-queue-info.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-IO-Config] Error: Cannot find module 'line-by-line'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/core/modbus-io-core.js
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-io-config.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Response-Filter] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-response-filter.js
31 Jul 09:55:05 - [warn] [node-red-contrib-modbus/Modbus-Flex-Sequencer] Error: Cannot find module 'bson'
Require stack:
- /data/node_modules/node-red-contrib-modbus/modbus/modbus-flex-sequencer.js
Require stack:
your credentials.
The flow I am using for testing is as following.
"id": "99177538a354aa2e",
"type": "tab",
"label": "Flow 5",
"disabled": false,
"info": "",
"env": []
"id": "6bacc885d0d54737",
"type": "inject",
"z": "99177538a354aa2e",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 200,
"y": 100,
"9f7e4c52468117a0"
"id": "9f7e4c52468117a0",
"type": "debug",
"name": "debug 1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 420,
"y": 100,
@Steve-Mcl node-red is deployed in Rancher platform in our corporate servers.
As you can see, the install of nodes is messed up.
I don't know anything about Rancher, but if this were a normal install I would recommend deleting the node_modules folder, which in your system appears to be /data/node-modules, then, in a command window, going into /data and running
npm install
which should re-install all the required nodes. Watch for errors with this obviously.
As for the sockets connection problem then it appears that the browser cannot open a web socket connection to the server. That may be a Rancher problem.
As rancher is container based (think docker) your images will need the tools necessary for compiling certain nodes that have a build step (like serial port etc)
Covered many times on the forum. Search "docker build serial"
