Today I tried to add a new device to my Homebridge via Nodered and I ended up crashing Homebridge.
I am using Homebridge-MQTT to interface Nodered and Homebridge but it seems like something changed.
Whenever Homebridge starts up I get an error on the topic "homebridge/from/#" saying
"Unexpected token h in JSON at position 0"
The error that shows up on the Homebridge Terminal is
[23/02/2021, 19:20:42] AssertionError [ERR_ASSERTION]: props cannot be undefined when setting props
at On.Characteristic.setProps (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Characteristic.ts:974:11)
at Accessory.setProps (/usr/lib/node_modules/homebridge-mqtt/lib/accessory.js:210:52)
at Accessory.configureCharacteristics (/usr/lib/node_modules/homebridge-mqtt/lib/accessory.js:155:14)
at Accessory.configureAccessory (/usr/lib/node_modules/homebridge-mqtt/lib/accessory.js:95:10)
at Controller.addAccessory (/usr/lib/node_modules/homebridge-mqtt/lib/controller.js:107:17)
at Model.<anonymous> (/usr/lib/node_modules/homebridge-mqtt/lib/model.js:153:22)
at MqttClient.emit (events.js:315:20)
at MqttClient._handlePublish (/usr/lib/node_modules/homebridge-mqtt/node_modules/mqtt/lib/client.js:1277:12)
at MqttClient._handlePacket (/usr/lib/node_modules/homebridge-mqtt/node_modules/mqtt/lib/client.js:410:12)
at work (/usr/lib/node_modules/homebridge-mqtt/node_modules/mqtt/lib/client.js:321:12)
Homebridge the restarts,
Anyone have experience with this issue ?
It also seems that Homebridge-MQTT is no longer being worked on, maybe this is the problem
Byron
