MQTT configuration nodes are not recognized when packaged in a subflow module
Structure
── node-red
│   └── subflows
│       ├── custom-nodes-internal-mqtt-in.js
│       ├── custom-nodes-internal-mqtt-in.json
│       ├── custom-nodes-internal-mqtt-out.js
│       └── custom-nodes-internal-mqtt-out.json
├── Dockerfile
├── package.json
After some painstaking deep dive into packaging subflow modules tried running things within a docker container only to find out that the configuration for mqtt broker node is not being read.
this is the adapted JSON file based on the packaging documentation for subflows
    "id": "45db115760787ca3",
    "type": "subflow",
    "name": "internal mqtt in",
    "info": "# Internal MQTT In Node\n\nAutomatically connects to the Internal MQTT Broker and subscribes to User-Defined MQTT Topics\n\n## Subscribe to MQTT Topics\n\nCreate an __Inject__ node with following:\n\n- `msg.action` = `subscribe`\n- `msg.topic` = `YOUR/TOPIC/HERE`\n\nand connect to this node\n\n## Disconnect from Internal MQTT Broker\n> NOTE: If you disconnect from the broker, you will need to reconnect again\n\nCreate an __Inject__ node with following:\n\n- `msg.action` = `disconnect`\n\nand connect to this node\n\n## Reconnect to Internal MQTT Broker\n\nCreate an __Inject__ node with following:\n\n- `msg.action` = `connect`\n\nand connect to this node\n\n## Unsubscribe from MQTT Topics\n\nCreate an __Inject__ node with following:\n\n- `msg.action` = `unsubscribe`\n- `msg.topic` = (select boolean) `true`\n\nand connect to this node",
    "category": "custom-nodes",
    "in": [
            "x": 220,
            "y": 100,
                    "id": "cd6f53791302e5d9"
    "out": [
            "x": 560,
            "y": 100,
                    "id": "cd6f53791302e5d9",
                    "port": 0
    "env": [],
    "meta": {
        "module": "subflow-mqtt-common",
        "type": "mqtt-internal-in",
        "version": "0.1.0",
        "author": "Shantanoo \"Shan\" Desai <sdes.softdev@gmail.com>",
        "desc": "MQTT In Node for Internal MQTT Broker",
        "keywords": "mqtt, subflows",
        "license": "Apache-2.0"
    "color": "#F3B567",
    "icon": "node-red/bridge.svg",
    "status": {
        "x": 540,
        "y": 180,
                "port": 0
    "flow": [
            "type": "mqtt in",
            "z": "45db115760787ca3",
            "name": "Internal MQTT Broker In",
            "topic": "",
            "qos": "2",
            "datatype": "auto",
            "broker": "1e34472ea3f09540",
            "nl": false,
            "rap": true,
            "rh": 0,
            "inputs": 1,
            "x": 390,
            "y": 100,
            "id": "1e34472ea3f09540",
            "type": "mqtt-broker",
            "name": "Internal MQTT Broker In Node",
            "broker": "internal-mqtt-broker",
            "port": "1883",
            "clientid": "red-client-mqtt-internal-in",
            "autoConnect": true,
            "usetls": false,
            "protocolVersion": "4",
            "keepalive": "60",
            "cleansession": true,
            "birthTopic": "",
            "birthQos": "0",
            "birthPayload": "",
            "birthMsg": {},
            "closeTopic": "",
            "closeQos": "0",
            "closePayload": "",
            "closeMsg": {},
            "willTopic": "",
            "willQos": "0",
            "willPayload": "",
            "willMsg": {},
            "sessionExpiry": "",
            "credentials": {
                "user": "",
                "password": ""
package.json
    "name"         : "node-red-mqtt-subflows",
    "version"      : "0.1.0",
    "description"  : "Custom MQTT Nodes for Distinct Broker using node-RED Subflows",
    "dependencies": {
        "node-red": ">=2.2.0"
    "keywords": [ "node-red" ],
    "node-red"     : {
        "version": ">=2.0.0",
        "nodes": {
            "custom-nodes-internal-mqtt-in": "node-red/subflows/custom-nodes-internal-mqtt-in.js",
            "custom-nodes-internal-mqtt-out": "node-red/subflows/custom-nodes-internal-mqtt-out.js"
    "scripts": {
        "start": "node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS --userDir=/data"
Dockerfile
FROM nodered/node-red:2.2.2
# Copy all node-red related files
COPY . /data
RUN npm install --unsafe-perm --no-update-notifier --no-audit --only=production /data
Result
Everything compiles great and I can see the nodes under custom palette I have created called custom-nodes however upon connecting an inject and debug node I get the following error:
node-red              | 25 Apr 19:09:46 - [error] [mqtt-internal-in:Internal MQTT Broker In] missing broker configuration
node-red              | 25 Apr 19:10:21 - [error] [mqtt-internal-out:MQTT Internal Broker Out] missing broker configuration
The configuration already exists in the flow array however it is not recognized
Related Queries
Hack / Solution
the Only possible solution is to export all the subflows as a single JSON and pack these flows into /data/flows.json
This maintains the MQTT configuration and one is able to connect to MQTT Broker.
node-red/flows.json
add the flows.json to the node-red/ directory
        "type": "subflow",
        "in": [
                "x": 220,
                "y": 100,
        "out": [
                "x": 560,
                "y": 100,
                        "port": 0
        "env": [],
        "meta": {
            "version": "0.1.0",
        "color": "#F3B567",
        "status": {
            "x": 540,
            "y": 180,
                    "port": 0
        "type": "mqtt in",
        "topic": "",
        "qos": "2",
        "datatype": "auto",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 1,
        "x": 390,
        "y": 100,
        "port": "1883",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "credentials": {
            "user": "",
            "password": ""
        "id": "ced02ad71788907a",
        "type": "subflow",
        "name": "internal mqtt out",
        "info": "# Internal MQTT Out Node\n\nAutomatically connects to the Internal MQTT Broker and publish to User-Defined MQTT Topics\n\n## Subscribe to MQTT Topics\n\nCreate an __Inject__ node with following:\n\n- `msg.topic` = `YOUR/TOPIC/HERE`\n\nand connect to this node\n\n## Disconnect from INternal MQTT Broker\n\n> NOTE: If you disconnect from the broker, you will need to reconnect again. \n\nCreate an __Inject__ node with following:\n\n- `msg.action` = `disconnect`\n\nand connect to this node\n\n## Reconnect to Internal MQTT Broker\n\nCreate an __Inject__ node with following:\n\n- `msg.action` = `connect`\n\nand connect to this node",
        "in": [
                "x": 160,
                "y": 180,
                        "id": "f40d0dbc09407cae"
        "out": [],
        "env": [],
        "meta": {
            "type": "mqtt-internal-out",
            "version": "0.1.0",
            "desc": "MQTT Out Node for Internal Broker",
        "color": "#F3B567",
        "id": "4afe4316918f609c",
        "z": "ced02ad71788907a",
        "name": "Internal MQTT Broker Out Node",
        "port": "1883",
        "clientid": "red-client-mqtt-internal-out",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "credentials": {
            "user": "",
            "password": ""
        "id": "f40d0dbc09407cae",
        "type": "mqtt out",
        "name": "MQTT Internal Broker Out",
        "topic": "",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "4afe4316918f609c",
        "x": 390,
        "y": 180,
Dockerfile
COPY node-red/flows.json /data/flows.json
COPY package.json .
