Mqtt in and out topic
I have a very simple flow that contains an mqtt-in node, two mqtt-out nodes and two function nodes.
the topic of the mqtt-in node is home/Garage/# and the topic of mqtt-out nodes are home/Garage/door/status and home/Garage/door/command.
obviously this simple flow has an issue which causes an infinite loop.
how can I fix the issue?
Thanks,
Hello @mohammad-torabi-84
Either subscribe to home/garage/+/status
Or (probably better) use command/home/garage/door and status/home/garage/door
So, these two topic of command/home/garage/door and status/home/garage/door have the same result. because the mqtt-out node has the same topic of the mqtt-in node. this will cause an infinite loop in the flow.
I misinterpreted your question.
  1. Presumably the messages that your flow sends on home/garage/door/command are instructions to the door -"Open", "Close" etc. ?
  2. Why does your flow send messages on home/garage/door/status?
    What device subscribes to these messages?
    I assumed that these messages would be sent by the door to indicate it's current state - "Opened", "Closed" etc.
  3. What device publishes the message that your mqtt-in node is intended to receive?
    Do you have control over the topic this device uses?
Add a Filter node in front of each mqtt out node. That should break the loop.
Your MQTT-In node is subscribing to the topic home/Garage/#
The hash # symbol is a wildcard which means the node will accept anything from that point onwards.
Your MQTT-Out nodes are publishing to the topic home/Garage/door/status and
If you write the topics out as a list you can see the overlap.
home/Garage/#
So your MQTT-In will react everytime you send a message. An infinite loop has been created.
As @jbudd said you need to adjust the topic names or as @Colin says add a 'Filter'node.
If you tell us what is in the function nodes, and why, there may be a better way of handling the problem.
