Hi, I'm trying to send a setpoint via mqtt over a esp8266 to an inverter. The message should be inverter/ctrl/limit/0 with a payload giving the setpoint. The payload could be from 2 to 100% (one could also leave out the adjancent %) or from 0-1500W. That leaves me unsure about the type of the message or the variable I connect to the mqtt node. Should it be a string or a number? Or does it make no difference? The Topic can be edited in the mqtt node as well as in the inject node. I suppose the one in the mqtt node is the one thats relevant. OK, if tryed this out, the message is fired and I can see it in my mosquitto_sub console. Nevertheless the Inverter does not understand this message saying that that a frame is missing:
16:34:16 I: (#0) enqueCommand: 0x0b
16:34:16 I: (#0) prepareDevInformCmd 0x0b
16:34:16 15 pid: 80
*16:34:16 I: TX 27B Ch40 | 15 83 12 88 54 86 28 43 35 80 0b 00 64 60 f1 68 00 00 00 07 00 00 00 00 80 00 11 *
16:34:16 W: (#0) Frame 1 missing: Request Retransmit
16:34:16 15 pid: 81
*16:34:16 I: TX 11B Ch61 | 15 83 12 88 54 86 28 43 35 81 01 *
Message is tried several times as configured. See answer script.
Before I updated the esp8266 board (Ahoy DTU) to versin 0.6.9 I sent the message using the Topic
inverter/ctrl/limit_persistent_absolute/0" -m "40
as the persistent_absolut is nomore used the message shortened to
Next question: What is " -m"40 good for. As I didn't know I left this out. I found no explanation for those "parameter".
But this old message worked somehow! Jet I can't get the new message together.
