My flow shows the MQTT nodes as disconnected, I'm running mosquitto. It runs on port 1883 and the MQTT nodes are configured to connect in localhost on port 1883
When I run Node-red "node-red", I get this error at the terminal:
11 Nov 09:54:42 - [info] Starting flows
ReferenceError: URL is not defined
at Object.connect (/usr/local/lib/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:64:18)
at MQTTBrokerNode.connect (/usr/local/lib/node_modules/node-red/node_modules/@node-red/nodes/core/network/10-mqtt.js:245:40)
at MQTTBrokerNode.register (/usr/local/lib/node_modules/node-red/node_modules/@node-red/nodes/core/network/10-mqtt.js:221:22)
at new MQTTInNode (/usr/local/lib/node_modules/node-red/node_modules/@node-red/nodes/core/network/10-mqtt.js:421:33)
at Object.createNode (/usr/local/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/util.js:493:31)
at Flow.start (/usr/local/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:194:48)
at start (/usr/local/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:345:33)
at <anonymous>
at process._tickCallback (internal/process/next_tick.js:188:7)
Should I remove mosquitto and install it again?
