janvda
7 September 2022 19:00
1
My setup:
On my intel NUC device with host OS ubuntu 20.4 I am running docker and in this case I make use of following docker containers:
MQTT broker (without security) based on docker image eclipse-mosquitto
several node-red containers (based on docker image nodered/node-red:3.0.2-16) which connect to the MQTT broker using the core node red MQTT node with below configuration (so no security):
The problem is that when I restart the Flows using the Node-Red editor for one of my node-red containers then most of the times it is disconnecting from the MQTT broker but NOT reconnecting.
So when it is working I get following expected log output:
niamondo-map-1 | 7 Sep 20:41:16 - [warn] Using unencrypted credentials
niamondo-map-1 | 7 Sep 20:41:16 - [info] Stopping flows
niamondo-map-1 | 7 Sep 20:41:16 - [info] Stopped flows
niamondo-map-1 | 7 Sep 20:41:16 - [info] Starting flows
niamondo-map-1 | 7 Sep 20:41:16 - [info] [worldmap:37add1f3.3f5cce] started at /worldmap
niamondo-map-1 | 7 Sep 20:41:16 - [info] Started flows
niamondo-mqtt-1 | 1662576076: Client nodered_d8aaeaa349a742d9 disconnected.
niamondo-mqtt-1 | 1662576076: New connection from 172.19.0.10:45648 on port 1883.
niamondo-mqtt-1 | 1662576076: New client connected from 172.19.0.10:45648 as nodered_4e0ec337db03012d (p2, c1, k60).
niamondo-map-1 | 7 Sep 20:41:16 - [info] [mqtt-broker:mqtt broker] Connected to broker: mqtt://mqtt:1883
niamondo-map-1 | 7 Sep 20:41:16 - [info] [debug:MQTT send map/state] not_initialized
niamondo-qr-scanner-1 | 7 Sep 20:41:16 - [info] [debug:MQTT receive map/state] not_initialized
but when I restarted it again 20 seconds later I got following unexpected output:
niamondo-map-1 | 7 Sep 20:41:31 - [warn] Using unencrypted credentials
niamondo-map-1 | 7 Sep 20:41:31 - [info] Stopping flows
niamondo-map-1 | 7 Sep 20:41:31 - [info] Stopped flows
niamondo-map-1 | 7 Sep 20:41:31 - [info] Starting flows
niamondo-map-1 | 7 Sep 20:41:31 - [info] [worldmap:37add1f3.3f5cce] started at /worldmap
niamondo-map-1 | 7 Sep 20:41:31 - [info] Started flows
niamondo-mqtt-1 | 1662576091: Client nodered_4e0ec337db03012d disconnected.
niamondo-map-1 | 7 Sep 20:41:31 - [info] [mqtt-broker:mqtt broker] Connected to broker: mqtt://mqtt:1883
niamondo-map-1 | 7 Sep 20:41:31 - [info] [debug:MQTT send map/state] not_initialized
So you can see in the above log file that my MQTT broker container niamondo-mqtt-1 is only reporting a disconnect but doesn't report a (client) connection.
Although the MQTT broker doesn't report a client connection, the node-red container niamondo-map-1 does report that it has connected to the broker which you can also see in the node-red editor:
I am pretty sure that my node-red container is not properly connected to the broker as it is not receiving any MQTT events that are sent by the other container niamondo-qr-scanner-1.
janvda
7 September 2022 19:36
2
I have found the root cause.
The problem is that it is connecting to a different MQTT broker container that is also running on the same Host OS.
I have opened a shell in my node-red container and ran netstat -a command.
Normally I should get something like:
bash-5.1$ netstat -a
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN
tcp 0 0 localhost:37205 0.0.0.0:* LISTEN
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54064 ESTABLISHED
tcp 0 0 localhost:1880 localhost:58900 TIME_WAIT
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54054 TIME_WAIT
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54062 TIME_WAIT
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54058 TIME_WAIT
tcp 0 0 localhost:1880 localhost:58890 TIME_WAIT
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54060 TIME_WAIT
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:53612 ESTABLISHED
tcp 0 0 ac91111b855f:45654 niamondo-mqtt-1.nuc1_default:1883 ESTABLISHED
udp 0 0 localhost:59880 0.0.0.0:*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags Type State I-Node Path
bash-5.1$
but when the problem happened I saw the following:
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54066 TIME_WAIT
tcp 0 0 localhost:1880 localhost:58924 TIME_WAIT
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54064 TIME_WAIT
tcp 0 0 localhost:1880 localhost:58934 TIME_WAIT
tcp 0 0 ac91111b855f:1880 traefik.nuc1_default:54068 ESTABLISHED
tcp 0 0 ac91111b855f:48928 nuc1-mqtt-1.nuc1_default:1883 ESTABLISHED
bash-5.1$
So you see that in the second netstat log a connection has been made with
while in the first netstats a connection has been made with a different host:
So it appears that after restarting the flows the mqtt hostname is suddenly resolved to a different IP address as you see here below:
bash-5.1$ ping mqtt
PING mqtt (172.19.0.3) 56(84) bytes of data.
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=1 ttl=64 time=0.125 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=2 ttl=64 time=0.120 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=3 ttl=64 time=0.120 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=4 ttl=64 time=0.121 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=5 ttl=64 time=0.122 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=6 ttl=64 time=0.133 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=7 ttl=64 time=0.119 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=8 ttl=64 time=0.118 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=9 ttl=64 time=0.120 ms
^C
--- mqtt ping statistics ---
9 packets transmitted, 9 received, 0% packet loss, time 8165ms
rtt min/avg/max/mdev = 0.118/0.122/0.133/0.004 ms
bash-5.1$ ping mqtt
PING mqtt (172.19.0.15) 56(84) bytes of data.
64 bytes from niamondo-mqtt-1.nuc1_default (172.19.0.15): icmp_seq=1 ttl=64 time=0.110 ms
64 bytes from niamondo-mqtt-1.nuc1_default (172.19.0.15): icmp_seq=2 ttl=64 time=0.121 ms
64 bytes from niamondo-mqtt-1.nuc1_default (172.19.0.15): icmp_seq=3 ttl=64 time=0.081 ms
64 bytes from niamondo-mqtt-1.nuc1_default (172.19.0.15): icmp_seq=4 ttl=64 time=0.120 ms
64 bytes from niamondo-mqtt-1.nuc1_default (172.19.0.15): icmp_seq=5 ttl=64 time=0.143 ms
64 bytes from niamondo-mqtt-1.nuc1_default (172.19.0.15): icmp_seq=6 ttl=64 time=0.194 ms
64 bytes from niamondo-mqtt-1.nuc1_default (172.19.0.15): icmp_seq=7 ttl=64 time=0.180 ms
^C
So it is not a node-red problem but a docker problem.
janvda
7 September 2022 19:59
3
I have fixed it by renaming my mqtt docker container into mqtt-broker so that it doesn't clash with existing mqtt docker container.
So ping mqtt-broker will always return the proper IP address which is different from the IP address returned by ping mqtt :
bash-5.1$ ping mqtt-broker
PING mqtt-broker (172.19.0.16) 56(84) bytes of data.
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=1 ttl=64 time=0.211 ms
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=2 ttl=64 time=0.120 ms
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=3 ttl=64 time=0.180 ms
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=4 ttl=64 time=0.194 ms
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=5 ttl=64 time=0.120 ms
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=6 ttl=64 time=0.133 ms
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=7 ttl=64 time=0.121 ms
64 bytes from niamondo-mqtt-broker-1.nuc1_default (172.19.0.16): icmp_seq=8 ttl=64 time=0.120 ms
^C
--- mqtt-broker ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time 7080ms
rtt min/avg/max/mdev = 0.120/0.149/0.211/0.036 ms
bash-5.1$ ping mqtt
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=1 ttl=64 time=0.316 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=2 ttl=64 time=0.196 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=3 ttl=64 time=0.125 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=4 ttl=64 time=0.196 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=5 ttl=64 time=0.121 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=6 ttl=64 time=0.181 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=7 ttl=64 time=0.133 ms
64 bytes from nuc1-mqtt-1.nuc1_default (172.19.0.3): icmp_seq=8 ttl=64 time=0.178 ms
^C
8 packets transmitted, 8 received, 0% packet loss, time 7059ms
rtt min/avg/max/mdev = 0.121/0.180/0.316/0.058 ms
bash-5.1$
