MQTT Reconnecting to Platform
Hello , I keep having this info in the device logs , is this something I should be aware of ? or is it just a normal process ? Why does it keeps on reconnecting to the platform and the Project Link Nodes also sometimes get closed , The flows are working fine , its just this info keeps on appearing sometimes so I thought maybe I should raise this issue because I don't know what is this info and it has been bugging me for a while ..
[AGENT] 17/04/2024 11:05:06 [info] MQTT connected
[AGENT] 17/04/2024 11:05:03 [info] MQTT reconnecting to platform
[AGENT] 17/04/2024 11:04:18 [info] MQTT reconnecting to platform
[NR] 17/04/2024 11:04:16 [info] Project Link nodes connected
[NR] 17/04/2024 11:04:03 [info] Project Link nodes connection closed
Hi.
Occasional blips should be nothing to worry about, but let's check....
How often do you see this in an hour? In a day?
Is your network and internet connection stable? (Do you have any means of checking this?)
Lastly, could you please tell me the version numbers of the device agent & the project nodes?
Thanks.
For now , i see this happening every 3 hour 30 min
This is the logs at 7am in the morning (Malaysia Time) - 1st time happened as of today
4/18/2024 7:04:03 AM  [info]    Project Link nodes connection closed
4/18/2024 7:04:15 AM  [info]    Project Link nodes connected
4/18/2024 7:04:18 AM  [info]    MQTT reconnecting to platform
4/18/2024 7:05:03 AM  [info]    MQTT reconnecting to platform
4/18/2024 7:05:06 AM  [info]    MQTT connected
This is the logs at 10am in the morning (Malaysia Time) - 2nd time happened as of today
4/18/2024 10:34:03 AM  [info]    Project Link nodes connection closed
4/18/2024 10:34:17 AM  [info]    Project Link nodes connected
4/18/2024 10:34:18 AM  [info]    MQTT reconnecting to platform
4/18/2024 10:35:03 AM  [info]    MQTT reconnecting to platform
4/18/2024 10:35:12 AM  [info]    MQTT connected
I wont say its very stable since the device are located in rural areas but to give you an idea , we only faced network connections down every 2 days and the downtime period are around 2 hours max
The Device Agent Version : 2.3.2
Project Node Version : 0.6.1
