MQTT retaining unwanted messages
I have a simple flow, Ubuntu server, 2 Pi-4 Clients. Communication via MQTT between clients and server.
On the server I set the MQTT out node to "Retain Message", so when the client would start it would get the last message. It worked. I no longer need this, but even though I unclicked "Retain Messages", then clients are always pulling a message.
Is there some cache I need clear or what have I missed!!!
Thanks in advance.
To clear a retained message on a topic, you need to publish an empty payload with the retain flag set.
Install the mosquitto-clients package. Then you can send the empty message to your server with the retain bit set from the command line:
mosquitto_pub -h your_server -t "yourTopic" -m "" -r
I find this easier and quicker than doing something with a flow.
Using MQTT explorer, you can select the retained item from the tree & simply click the delete button.
Is MQTT explorer in Node-Red or is it an external app?
External application for browsing / viewing your MQTT broker (very professional & user friendly)
Wow, Very good program, handy to have, serious information in it. Thank you.
