Can someone help me with this code? I'd like to trigger a Led when the value of the payload is > 1000.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char *ssid = "xxx";
const char *password = "xxx";
const char *mqtt_server = "xxxx";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
int led = D4;
void setup_wifi()
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void callback(char *topic, byte *payload, unsigned int length)
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++)
Serial.print((char)payload[i]);
Serial.println();
// Switch on the LED if value of C02 is above 1000
if ((char)payload[0] > '1000') // This is where it goes wrong!
digitalWrite(led, HIGH); // Turn the LED on
else
digitalWrite(led, LOW); // Turn the LED off
void reconnect()
// Loop until we're reconnected
while (!client.connected())
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str()))
Serial.println("connected");
// Once connected, publish an announcement...
//client.publish("outTopic", "Test");
// ... and resubscribe
client.subscribe("my/sensors/co2");
else
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup()
pinMode(led, OUTPUT); // Initialize the BUILTIN_LED pin as an output
Serial.begin(115200);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
void loop()
if (!client.connected())
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 2000)
lastMsg = now;
++value;
snprintf(msg, 50, "Fx235 #%ld", value);
Serial.print("Publish message: ");
Serial.println(msg);
client.publish("outTopic", msg);
Kind regards
