Is this expected and known or is a bug?
I struggled for so long why my flow is not working, but accidentally found out that the msg.flush works only if DIRECTLY connected to the rate limit node.
the two top flows are identical, but one is connected with link node and other directly.
the one with link node 'adds' a message, and ends up sending out double the number of outputs from the split node.
or am i making any mistake ?
[{"id":"4ea54cf4d8d4b477","type":"delay","z":"400bc99efba52b23","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":760,"y":5120,"wires":[["f8319cacfeab6fbd"]]},{"id":"e7117d68cc152fd8","type":"split","z":"400bc99efba52b23","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","property":"payload","x":580,"y":4960,"wires":[["00e7be9d278050ed","4ea54cf4d8d4b477"]]},{"id":"893c66cda16a3528","type":"link in","z":"400bc99efba52b23","name":"link in 322","links":["d142f452f605bfc1"],"x":605,"y":5120,"wires":[["4ea54cf4d8d4b477"]]},{"id":"f8319cacfeab6fbd","type":"delay","z":"400bc99efba52b23","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":960,"y":5120,"wires":[["b50b7fbb45f7c33e"]]},{"id":"f1bb14a36ca6596f","type":"inject","z":"400bc99efba52b23","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[9,8,7,6,5,4,3,2,1,0]","payloadType":"json","x":420,"y":4960,"wires":[["e7117d68cc152fd8"]]},{"id":"00e7be9d278050ed","type":"delay","z":"400bc99efba52b23","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":760,"y":4960,"wires":[["3e0628594eb34a78"]]},{"id":"b50b7fbb45f7c33e","type":"debug","z":"400bc99efba52b23","name":"debug 2935","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":1150,"y":5120,"wires":[]},{"id":"0ebb3ae15c4e8320","type":"function","z":"400bc99efba52b23","name":"Flush","func":"return {flush:1};","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":5020,"wires":[["00e7be9d278050ed","d142f452f605bfc1"]]},{"id":"3e0628594eb34a78","type":"delay","z":"400bc99efba52b23","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":960,"y":4960,"wires":[["e14a1c0858c3d9d1","020e962ffd3d6137"]]},{"id":"e7c327ea272c72fb","type":"junction","z":"400bc99efba52b23","x":440,"y":5000,"wires":[["0ebb3ae15c4e8320"]]},{"id":"d142f452f605bfc1","type":"link out","z":"400bc99efba52b23","name":"link out 470","mode":"link","links":["893c66cda16a3528"],"x":545,"y":5060,"wires":[]},{"id":"e14a1c0858c3d9d1","type":"debug","z":"400bc99efba52b23","name":"debug 2934","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"","statusType":"counter","x":1150,"y":4960,"wires":[]},{"id":"020e962ffd3d6137","type":"junction","z":"400bc99efba52b23","x":1040,"y":4980,"wires":[["e7c327ea272c72fb"]]}]
