easy question for you all. I am trying to set a variable: msg.payload: 10, in a json format. The msg.payload : 10 must replace the "timeout" : 20
"payload": "on",
"timeout": 20,
"warning": 5
thanks.
Hi @Duncan
Just to clarify, you want to set msg.payload to the object:
"payload": "on",
"timeout": 20,
"warning": 5
but you want to replace the timeout value (20 in the example) with the existing value of msg.payload?
If that is the case, then a Function node with the follow would do it:
msg.payload = {
"payload": "on",
"timeout": msg.payload,
"warning": 5
If that isn't what you meant, then maybe you could clarify.
exactly what I meant, thanks it works. I might just get the hang of this eventually.
