Msg.topic manipilation of output of a function node
A newbie question.... Again....
I have a function node that has a few outputs, what is the correct way of setting a different topic for a particular output?
ie:
return [ {payload:0}, {payload:1} ];
Sets the payloads for the outputs.... How do I set the topics (individually) for them too?
Tia
Ed
return [ {topic: "topic1", payload:0}, {topic: "topic2", payload:1} ];
Its just an object property.
A tiny bit of JS training around objects and arrays would help you greatly here. so here goes...
long hand version...
var msg1 = {}; //create an empty object
msg1.topic = "topic1"; //add a topic property
msg1.payload = 0; //add a payload property
var msg2 = {};//create an empty object
msg2.topic = "topic2";//add a topic property
msg2.payload = 1; //add a payload property
return [ msg1, msg2 ];
another version...
var msg1 = {
  topic : "topic1",
  payload : 0
var msg1 = {
  topic : "topic2",
  payload : 1
One more...
var messages = []; //an empty array
messages.push( {  topic : "topic1",  payload : 0 } ); //push an object into the array
messages.push( {  topic : "topic2",  payload : 1 } ); //push an object into the array
return messages; //return the array
hopefully that helps you understand some things?
@Steve-Mcl
Indeed it does!!
Thank you yet again!!
Ed
