Hello, the Nodered server is not on the same machine as the SQL server.
On Github is nothing related with this error.
Now for the flows:
Flow A:
        "id": "15b82b89.7ee7dc",
        "type": "function",
        "z": "b4f95417.221508",
        "name": "Split String",
        "func": "var msg = msg.payload;\nvar DevID={ payload: parseInt(msg.slice(40,42),16)};\nvar Pluv1={ payload: parseInt(msg.slice(0,4),16)/100};\nvar Pluv2={ payload: parseInt(msg.slice(4,8),16)/100};\nvar Pluv3={ payload: parseInt(msg.slice(8,12),16)/100};\nvar Wind={ payload: parseInt(msg.slice(12,18),16)};\nvar Anemo={ payload: parseInt(msg.slice(18,22),16)/100};\nvar Tempsign={ payload: parseInt(msg.slice(22,24),16)};\nvar Temp={ payload: parseInt(msg.slice(24,28),16)/100};\nif (Tempsign.payload == 1) (Temp = { payload: (Temp.payload * (-1))});\nvar Hum={ payload: parseInt(msg.slice(28,32),16)/100};\nvar Press={ payload: parseInt(msg.slice(32,38),16)};\nvar Bat={ payload: parseInt(msg.slice(38,40),16)};\nreturn [DevID,Pluv1,Pluv2,Pluv3,Wind,Anemo,Temp,Hum,Press,Bat];",
        "outputs": 10,
        "noerr": 0,
        "x": 1050,
        "y": 420,
                "c46309a1.359578",
                "f7e42d18.d1804"
                "73bf16e0.ee2438",
                "f7e42d18.d1804"
                "23cc97.366abb6a",
                "f7e42d18.d1804"
                "1bfe6a6e.ba4ee6",
                "f7e42d18.d1804"
                "47911896.8df1b8",
                "f7e42d18.d1804"
                "e60d01e1.adf32",
                "f7e42d18.d1804"
                "29ed72f4.c4c06e",
                "f7e42d18.d1804"
                "344664c2.26020c",
                "f7e42d18.d1804"
                "721cbc1b.9ca88c",
                "f7e42d18.d1804"
                "dfff80a0.04af5",
                "f7e42d18.d1804"
        "id": "f7e42d18.d1804",
        "type": "join",
        "mode": "custom",
        "build": "array",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": false,
        "timeout": "",
        "count": "10",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 1210,
        "y": 420,
                "be047bfa.63f268"
        "id": "be047bfa.63f268",
        "type": "simple-queue",
        "name": "Insert to DB queue",
        "firstMessageBypass": true,
        "bypassInterval": "0",
        "x": 1390,
        "y": 420,
                "a802c590.5c8848"
        "id": "a802c590.5c8848",
        "type": "MSSQL",
        "mssqlCN": "989023f3.29ffc8",
        "name": "WeatherStationsReads",
        "query": "DECLARE @StoreTime as DATETIME;\n\nSET @StoreTime = CURRENT_TIMESTAMP;\n\nINSERT INTO cStoreWeatherStations\n(\n[ReadTime]\n,[DevID]\n,[CurrentHAccRainfall]\n,[PreviousHAccRainfall]\n,[Last24HAccRainfall]\n,[WindDirection]\n,[Anemometer]\n,[Temperature]\n,[Humidity]\n,[Pressure]\n,[BatteryLevel]\n)\nVALUES\n    (\n     @StoreTime,\n     {{{payload.0}}},\n     {{{payload.1}}},\n     {{{payload.2}}},\n     {{{payload.3}}},\n     {{{payload.4}}},\n     {{{payload.5}}},\n     {{{payload.6}}},\n     {{{payload.7}}},\n     {{{payload.8}}},\n     {{{payload.9}}}\n    )",
        "outField": "payload",
        "x": 1610,
        "y": 420,
                "4c299039.e10c58"
        "id": "989023f3.29ffc8",
        "type": "MSSQL-CN",
        "z": "",
        "tdsVersion": "7_4",
        "name": "WeatherStations",
        "server": "10.80.x.x",
        "port": "1433",
        "encyption": false,
        "database": "WeatherST",
        "useUTC": false,
        "connectTimeout": "15000",
        "requestTimeout": "15000",
        "cancelTimeout": "5000",
        "pool": "10"
Flow B:
        "id": "bd3d408c.87daf",
        "type": "function",
        "z": "374f65b3.b9a9ea",
        "func": "var i;\nfor (i = 0; i < msg.payload.length; i++)\n\nvar UpTimeEpoch = { payload: parseInt(msg.payload[1].slice(9,19))};\n//var UpTime = { payload: parseInt(msg.payload[1].slice(9,19))};\n//var days = Math.trunc(UpTime.payload / (24*3600));\n//var time = (new Date((UpTime.payload - days*24*3600) * 1000)).toUTCString().match(/(\\d\\d:\\d\\d:\\d\\d)/)[0];\n//UpTime.payload = days + \":\" + time;\nvar Load1min = { payload: parseFloat(msg.payload[2].slice(8,13))};\nvar Load5min = { payload: parseFloat(msg.payload[3].slice(0,5))};\nvar Load15min = { payload: parseFloat(msg.payload[4].slice(0,5))};\nvar UsedMem = { payload: parseInt(msg.payload[5].slice(14,20))};\nvar FreeMem = { payload: parseInt(msg.payload[6].slice(7,13))};\nvar GatewayID = { payload: parseInt(msg.payload[8])};\n\nreturn [UpTimeEpoch,Load1min,Load5min,Load15min,UsedMem,FreeMem,GatewayID];",
        "outputs": 7,
        "noerr": 0,
        "x": 890,
        "y": 300,
                "1b351a9c.1e2ef5"
                "1b351a9c.1e2ef5"
                "1b351a9c.1e2ef5"
                "1b351a9c.1e2ef5"
                "1b351a9c.1e2ef5"
                "1b351a9c.1e2ef5"
                "1b351a9c.1e2ef5"
        "id": "1b351a9c.1e2ef5",
        "type": "join",
        "mode": "custom",
        "build": "array",
        "key": "topic",
        "joiner": "\\n",
        "timeout": "",
        "count": "7",
        "reduceExp": "",
        "reduceInit": "",
        "reduceFixup": "",
        "x": 1050,
        "y": 300,
                "84611128.5813f"
        "id": "84611128.5813f",
        "bypassInterval": "5000",
        "x": 1210,
        "y": 300,
                "8cf86df0.72483",
                "abca801e.ac13d8"
        "id": "abca801e.ac13d8",
        "type": "MSSQL",
        "mssqlCN": "cd65dbe6.c215d",
        "name": "GatewayStats",
        "query": "DECLARE @StoreTime as DATETIME;\n\nSET @StoreTime = CURRENT_TIMESTAMP;\n\nINSERT INTO GatewayStats\n(\n[ReadTime]\n,[GatewayID]\n,[UpTime]\n,[LoadOne]\n,[LoadFive]\n,[LoadFifteen]\n,[RamUsed]\n,[RamFree]\n)\nVALUES\n    (\n     @StoreTime,\n     {{{payload.6}}},\n     {{{payload.0}}},\n     {{{payload.1}}},\n     {{{payload.2}}},\n     {{{payload.3}}},\n     {{{payload.4}}},\n     {{{payload.5}}}\n    )\n    ",
        "x": 1420,
        "y": 300,
        "id": "cd65dbe6.c215d",
        "type": "MSSQL-CN",
        "z": "",
        "name": "IoT",
        "port": "1433",
        "encyption": false,
        "database": "IoT",
        "useUTC": false,
        "pool": "10"
