I have no problems accessing tables from two different databases in two different flows. The mysql is installed on the same machine as I am testing on using node-red-contrib-mysql
using a simple select:
- if you only have database/tab/e
Ain the flows, does it work? - If you swap out database/tab/e
Afor database/tab/eBin the flows, does it work? - what is the full name of the node you are using?
If you still have a problem, please provide your flows but read this first: How to share code or flow json
