Hello ,
I have a problem with node MSSQL.
I made a flow with the node which until now worked perfectly. I encountered a problem if the node receives too many packets it displays error connection closed. I am obliged to set a node delay in order to make my flow work.
Are using the old/umsuported node-red-contrib-mssql or newer maintained node-red-contrib-mssql-plus?
I use mssql not mssql-plus but after the node is ok
You should update...
