DesP
1
Hi All,
As per the title, I am getting the following error:
The node is configured like this:
My stored procedure (usp_My_Insert) is in the "Stored Procedures" folder in SQL Server. It works fine on the server.
The connection node used in this flow works fine for other SQL tasks.
All thoughts appreciated
try prefixing it with dbo. (or whatever schema it belongs to)
It could also be a permission issue (does the account setup on the config have EXECUTE permissions on the stored procedure?)
DesP
3
Hi Steve,
I have tried with and without the "dbo." with no success.
The permissions are as this:
Any further thoughts?
If i call a mssql sp from node-red, i use the scheme (with brackets!)
[dbname].[schema].[uspname]
Have you tried this?
DesP
6
@kitori Perfect! That worked straight away
For interest the SQL User Account has access to multiple databases, so thinking about it, your fix probably makes perfect sense
Thanks to all.
