vtgav
                    15 November 2018 10:03
                  1
              Greetings,
I run node-red  with pm2 using :-
pm2 start node-red
which works fine.
I can manually start a second instance with its own settings file from the command line :-
node-red -s node-red2/settings.js -u node-red2 &
and this works fine . . .
Any ideas how I can manage the second instance through pm2 aswell, so it autostarts etc. ?
I've tried
pm2 start node-red --name "node-red2" --node-args="-s node-red2/settings.js -u node-red2"
which errored trying to start node-red2 and also had the interesting side effect of killing the initial node-red instance
any ideas appreciated,
              Hi Gav,
The first thing I would try is setting the port number on the pm2 call ... i.e. -p. If the two instances of node-red are fighting for the same port that might be the problem.
              You will need to create a process file with your 2 instances, see http://pm2.keymetrics.io/docs/usage/application-declaration/
              Create PM2 ecosystem file like this:
pm2 ecosystem simple
PM2 will generate ecosystem.config.js
In ecosystem.config.js will add  new node-red session with argument file like this:
module.exports = {
where name: is new seesion name,
I will list changes in settings_greci.js  bellow:
I used port 20000 for new instance:
uiPort: process.env.PORT || 20000,
and new flow file:
