Multiple Paths with Sleeps
I'm trying to control 3x RGB bulbs and have them cycle through two colors (Red and Green). Often only one of the bulbs change colors and the other two remain constant with their first color. The path circled in red continues. From googling I think the sleeps are blocking the other paths from running. Is that correct? A weird thing I noticed is if I put a debug statement anywhere in the bulb 1 or 2 path it works fine.
[{"id":"8411e384.fb1f9","type":"subflow","name":"Inovelli Scenes","info":"","category":"","in":[{"x":120,"y":220,"wires":[{"id":"1adf8d0e.cac7f3"}]}],"out":[{"x":680,"y":40,"wires":[{"id":"3faf3597.ea43ba","port":0}]},{"x":680,"y":80,"wires":[{"id":"3faf3597.ea43ba","port":1}]},{"x":680,"y":120,"wires":[{"id":"3faf3597.ea43ba","port":2}]},{"x":680,"y":160,"wires":[{"id":"3faf3597.ea43ba","port":3}]},{"x":680,"y":200,"wires":[{"id":"3faf3597.ea43ba","port":4}]},{"x":680,"y":240,"wires":[{"id":"eee43bc5.cec848","port":0}]},{"x":680,"y":280,"wires":[{"id":"eee43bc5.cec848","port":1}]},{"x":680,"y":320,"wires":[{"id":"eee43bc5.cec848","port":2}]},{"x":680,"y":360,"wires":[{"id":"eee43bc5.cec848","port":3}]},{"x":680,"y":400,"wires":[{"id":"eee43bc5.cec848","port":4}]},{"x":680,"y":440,"wires":[{"id":"7247d146.a727a","port":0}]}],"env":[],"color":"#DDAA99","outputLabels":["Single tap up","Double tap up","Triple tap up","Quad tap up","5 taps up","Single tap down","Double tap down","Triple tap down","Quad Tap down","5 taps down","Config tap"]},{"id":"1adf8d0e.cac7f3","type":"switch","z":"8411e384.fb1f9","name":"Scene ID","property":"payload.event.label","propertyType":"msg","rules":[{"t":"eq","v":"Scene 001","vt":"str"},{"t":"eq","v":"Scene 002","vt":"str"},{"t":"eq","v":"Scene 003","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":220,"y":220,"wires":[["eee43bc5.cec848"],["3faf3597.ea43ba"],["7247d146.a727a"]]},{"id":"eee43bc5.cec848","type":"switch","z":"8411e384.fb1f9","name":"Scene Value (Down)","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"},{"t":"eq","v":"KeyPressed2x","vt":"str"},{"t":"eq","v":"KeyPressed3x","vt":"str"},{"t":"eq","v":"KeyPressed4x","vt":"str"},{"t":"eq","v":"KeyPressed5x","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":460,"y":260,"wires":[[],[],[],[],[]],"outputLabels":["Double Tap Down","Triple Tap Down","Quad Tap Down","5 Tap Down",""]},{"id":"3faf3597.ea43ba","type":"switch","z":"8411e384.fb1f9","name":"Scene Value (Up)","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"},{"t":"eq","v":"KeyPressed2x","vt":"str"},{"t":"eq","v":"KeyPressed3x","vt":"str"},{"t":"eq","v":"KeyPressed4x","vt":"str"},{"t":"eq","v":"KeyPressed5x","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":450,"y":180,"wires":[[],[],[],[],[]],"outputLabels":["","Single Tap Up","","",null]},{"id":"7247d146.a727a","type":"switch","z":"8411e384.fb1f9","name":"Scene Value (Config)","property":"payload.event.value","propertyType":"msg","rules":[{"t":"eq","v":"KeyPressed","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":460,"y":320,"wires":[[]],"outputLabels":["Single Config Tap"]},{"id":"471c4130132514cc","type":"tab","label":"Kitchen Fun","disabled":false,"info":""},{"id":"8ca6f983eaf41bb8","type":"subflow:8411e384.fb1f9","z":"471c4130132514cc","name":"","x":460,"y":160,"wires":[[],[],[],["684eeadbee3996a8","ee0f9910da1b03d6","e7d18c69bcc7340e"],[],[],[],[],["d6cf8828b3d1e04d","5c660bdefd507053","de0f3f0dd25a2816","aaa70bf4098945d0"],[],[]]},{"id":"b73666fc26b895a7","type":"switch","z":"471c4130132514cc","name":"Kitchen Table","property":"payload.event.node_id","propertyType":"msg","rules":[{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":220,"y":200,"wires":[["8ca6f983eaf41bb8"]]},{"id":"05fd2e06a5b0bd74","type":"server-events","z":"471c4130132514cc","name":"","server":"e976d2f1.a9534","version":1,"event_type":"zwave_js_value_notification","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":180,"y":80,"wires":[["b73666fc26b895a7"]]},{"id":"e7d18c69bcc7340e","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Green1","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_1","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#00ff00\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":170,"y":720,"wires":[["4081a529b7a5f253"]]},{"id":"4081a529b7a5f253","type":"api-call-service","z":"471c4130132514cc","name":"Disable white1","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_1","data":"{    \"command_class\": '51',    \"property\": \"targetColor\",    \"value\": '0',    \"property_key\": '0'}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":380,"y":720,"wires":[["a64c11986892c64c"]]},{"id":"a64c11986892c64c","type":"stoptimer","z":"471c4130132514cc","duration":"3","units":"Second","payloadtype":"num","payloadval":"0","name":"3","x":610,"y":720,"wires":[["6316944e1eccbd22"],[]]},{"id":"6316944e1eccbd22","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Red","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_1","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#ff0000\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":160,"y":780,"wires":[["1bd7c15bf21a7567"]]},{"id":"1bd7c15bf21a7567","type":"stoptimer","z":"471c4130132514cc","duration":"3","units":"Second","payloadtype":"num","payloadval":"0","name":"3","x":310,"y":780,"wires":[["7ba4c8dd363b8dbd"],[]]},{"id":"7ba4c8dd363b8dbd","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Green","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_1","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#00ff00\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":480,"y":780,"wires":[["a64c11986892c64c"]]},{"id":"ee0f9910da1b03d6","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Green2","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_2","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#00ff00\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":190,"y":580,"wires":[["5682df3c56fe4fda"]]},{"id":"5682df3c56fe4fda","type":"stoptimer","z":"471c4130132514cc","duration":"0.5","units":"Second","payloadtype":"num","payloadval":"0","name":"0.5","x":350,"y":580,"wires":[["2d7bc25af0f5e1d6"],[]]},{"id":"2d7bc25af0f5e1d6","type":"api-call-service","z":"471c4130132514cc","name":"Disable white2","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_2","data":"{    \"command_class\": '51',    \"property\": \"targetColor\",    \"value\": '0',    \"property_key\": '0'}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":500,"y":580,"wires":[["bb9e30cd4beb315f"]]},{"id":"bb9e30cd4beb315f","type":"stoptimer","z":"471c4130132514cc","duration":"2","units":"Second","payloadtype":"num","payloadval":"","name":"2","x":750,"y":580,"wires":[["52447e881e675346"],[]]},{"id":"745c4d5809406b4d","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Green","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_2","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#00ff00\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":600,"y":640,"wires":[["bb9e30cd4beb315f"]]},{"id":"f37573588fcc7b5c","type":"stoptimer","z":"471c4130132514cc","duration":"2","units":"Second","payloadtype":"num","payloadval":"","name":"2","x":430,"y":640,"wires":[["745c4d5809406b4d"],[]]},{"id":"52447e881e675346","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Red","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_2","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#ff0000\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":280,"y":640,"wires":[["f37573588fcc7b5c"]]},{"id":"684eeadbee3996a8","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Green3","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_3","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#00ff00\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":190,"y":440,"wires":[["f2245f91499085f2"]]},{"id":"f2245f91499085f2","type":"stoptimer","z":"471c4130132514cc","duration":"1","units":"Second","payloadtype":"num","payloadval":"0","name":"1","x":350,"y":440,"wires":[["e23d70053205100a"],[]]},{"id":"e23d70053205100a","type":"api-call-service","z":"471c4130132514cc","name":"Disable white3","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_3","data":"{    \"command_class\": '51',    \"property\": \"targetColor\",    \"value\": '0',    \"property_key\": '0'}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":500,"y":440,"wires":[["6fa6b0ae7b703099"]]},{"id":"6fa6b0ae7b703099","type":"stoptimer","z":"471c4130132514cc","duration":"2.5","units":"Second","payloadtype":"num","payloadval":"0","name":"2.5","x":670,"y":440,"wires":[["cc8818adc8cbc827"],[]]},{"id":"70d039f35e1b150f","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Green","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_3","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#00ff00\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":600,"y":500,"wires":[["6fa6b0ae7b703099"]]},{"id":"196b6c9b8d01a3ad","type":"stoptimer","z":"471c4130132514cc","duration":"2.5","units":"Second","payloadtype":"num","payloadval":"","name":"2.5","x":430,"y":500,"wires":[["70d039f35e1b150f"],[]]},{"id":"cc8818adc8cbc827","type":"api-call-service","z":"471c4130132514cc","name":"Prestage Red","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_3","data":"{    \"command_class\": '51',    \"property\": \"hexColor\",    \"value\": \"#ff0000\"    }","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":280,"y":500,"wires":[["196b6c9b8d01a3ad"]]},{"id":"d6cf8828b3d1e04d","type":"api-call-service","z":"471c4130132514cc","name":"Disable white1","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_1","data":"{    \"command_class\": '51',    \"property\": \"targetColor\",    \"value\": '255',    \"property_key\": '0'}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":800,"y":240,"wires":[[]]},{"id":"5c660bdefd507053","type":"api-call-service","z":"471c4130132514cc","name":"Disable white2","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_2","data":"{    \"command_class\": '51',    \"property\": \"targetColor\",    \"value\": '255',    \"property_key\": '0'}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":800,"y":200,"wires":[[]]},{"id":"de0f3f0dd25a2816","type":"api-call-service","z":"471c4130132514cc","name":"Disable white3","server":"e976d2f1.a9534","version":3,"debugenabled":false,"service_domain":"zwave_js","service":"set_value","entityId":"light.kitchen_bulb_3","data":"{    \"command_class\": '51',    \"property\": \"targetColor\",    \"value\": '255',    \"property_key\": '0'}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":800,"y":160,"wires":[[]]},{"id":"aaa70bf4098945d0","type":"change","z":"471c4130132514cc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":340,"wires":[["6fa6b0ae7b703099","bb9e30cd4beb315f","a64c11986892c64c"]]},{"id":"e976d2f1.a9534","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true}]
Simply adding a debug node cannot make any difference to the main flow, unless you have some sort of race condition.
Are those Home Assistant nodes? If so then I can't help with that aspect. Possible a Filter (previously RBE) node might help. That can block messages that are the same as the previous ones, but it depends on the exact mechanism of the loop.
Hi This may help you find the problem. https://discourse.nodered.org/t/message-debug-function-node/53261
Zwave RGB bulbs in Home Assistant zwavejs2mqtt
