Multiple physical buttons GPIO - only one push button at a time + RGB strip and relays sequence with variable delays
My project is simple for now:
I have 3 physical buttons which I connected to my relay board. Each button is connected to a separate relay and what node can I use to prevent simultaneous pressing of two or three buttons at the same time. I am looking the whole web to do so but there are all topics with one button or multiple presses on a single button.
I want to make the whole sequences for each buttons with relays but for know I must know how to push only one button at the same time.
I think the function node will be helpful for that but I don't know javascript language.
I will be very grateful for your help
I'm guessing the physical buttons "lock" when pressed.
So you press it, and it stays in a condition.
You press it again and the condition toggles.
I don't know if that will be easy.
You may need to go to press buttons (momentary press, non-locking).
Then you will have to make a bit of code.
Each button sets a topic for its message.
All 3 messages are sent into a node (function) and a lot of work happens in there.
Sorry, it is 21:11 local time and I woke up this morning at 05:45 local.
(Gotta love insomnia.) :frowning:
Here is a sample of how you could do it with the trigger node
[{"id":"ed9404a32493f348","type":"inject","z":"dd25585074ececfb","name":"button 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 1","payloadType":"str","x":220,"y":80,"wires":[["fa397cd50e53da64"]]},{"id":"5d44870ef3d8fcc9","type":"debug","z":"dd25585074ececfb","name":"relay 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":80,"wires":[]},{"id":"542ec01399d74cdf","type":"inject","z":"dd25585074ececfb","name":"button 2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 2","payloadType":"str","x":220,"y":140,"wires":[["fa397cd50e53da64"]]},{"id":"f6aac4011f02294d","type":"inject","z":"dd25585074ececfb","name":"button 3","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 3","payloadType":"str","x":220,"y":200,"wires":[["fa397cd50e53da64"]]},{"id":"504994e68a6fd402","type":"debug","z":"dd25585074ececfb","name":"relay 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":140,"wires":[]},{"id":"8ab0c75a9b116c02","type":"debug","z":"dd25585074ececfb","name":"relay 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":870,"y":200,"wires":[]},{"id":"4974e765e65fc82b","type":"switch","z":"dd25585074ececfb","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"button 1","vt":"str"},{"t":"eq","v":"button 2","vt":"str"},{"t":"eq","v":"button 3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":630,"y":140,"wires":[["5d44870ef3d8fcc9"],["504994e68a6fd402"],["8ab0c75a9b116c02"]]},{"id":"fa397cd50e53da64","type":"trigger","z":"dd25585074ececfb","name":"","op1":"","op2":"0","op1type":"pay","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":420,"y":140,"wires":[["4974e765e65fc82b"]]},{"id":"7b5fb12647fcae7d","type":"inject","z":"dd25585074ececfb","name":"RESET","props":[{"p":"reset","v":"reset","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":300,"wires":[["fa397cd50e53da64"]]}]
Thank you Trying_to_learn and zenofmud.
I have Raspberry Pi4 and I want to use GPIO 3 physical push button to steer some sequences with relays. Each sequence will take 120 seconds. Now when I push button it doesn't "lock" when pressed is momentary.
So with trigger node I must prevent other buttons to activate other sequences for 120 seconds
@zenofmud has a good starting point.
I am new to NR 3.x
I don't want to step on his work, but I would do it slightly different.
Rather than the 4'th inject: a delay node set to 120 seconds and it sends the reset message.
Something like this:
[{"id":"fa397cd50e53da64","type":"trigger","z":"0918ee609bf69fc7","name":"","op1":"","op2":"0","op1type":"pay","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":2900,"y":3950,"wires":[["4974e765e65fc82b","5208e2ef16afd9b6"]]},{"id":"ed9404a32493f348","type":"inject","z":"0918ee609bf69fc7","name":"button 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 1","payloadType":"str","x":2700,"y":3890,"wires":[["fa397cd50e53da64"]]},{"id":"542ec01399d74cdf","type":"inject","z":"0918ee609bf69fc7","name":"button 2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 2","payloadType":"str","x":2700,"y":3950,"wires":[["fa397cd50e53da64"]]},{"id":"f6aac4011f02294d","type":"inject","z":"0918ee609bf69fc7","name":"button 3","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 3","payloadType":"str","x":2700,"y":4010,"wires":[["fa397cd50e53da64"]]},{"id":"90312086218313de","type":"change","z":"0918ee609bf69fc7","name":"","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3070,"y":4060,"wires":[["fa397cd50e53da64"]]},{"id":"4974e765e65fc82b","type":"switch","z":"0918ee609bf69fc7","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"button 1","vt":"str"},{"t":"eq","v":"button 2","vt":"str"},{"t":"eq","v":"button 3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":3110,"y":3950,"wires":[["5d44870ef3d8fcc9"],["504994e68a6fd402"],["8ab0c75a9b116c02"]]},{"id":"5208e2ef16afd9b6","type":"delay","z":"0918ee609bf69fc7","name":"","pauseType":"delay","timeout":"120","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":3060,"y":4020,"wires":[["90312086218313de"]]},{"id":"5d44870ef3d8fcc9","type":"debug","z":"0918ee609bf69fc7","name":"relay 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3350,"y":3890,"wires":[]},{"id":"504994e68a6fd402","type":"debug","z":"0918ee609bf69fc7","name":"relay 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3350,"y":3950,"wires":[]},{"id":"8ab0c75a9b116c02","type":"debug","z":"0918ee609bf69fc7","name":"relay 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3350,"y":4010,"wires":[]}]
No offense @zenofmud
I am sorry but I am beginner with node-red so it will be best to swap Reset node with delay node?
That is something you left out in your original post BUT it is easy enough to handle, just edit the trigger node and change it like this:
and you can get rid of the 'Reset' button
[EDIT] changed the then send to nothing
(Sorry again)
But neither of the flows allow toggling of the output.
But that could be handled after the switch node with a function node that toggles.
@aquapark_lodz do you want all 3 buttons disabled for 120 seconds though?
So you press a button and can't press another for 120 seconds?
Or just don't want more than one pressed at any one time?
My original image needed a change
Here's a very quick modification of the flow created by @zenofmud
Once a button has been clicked, the delay is triggered so further clicks are ignored until 'msg.reset'.
[{"id":"f34f56a1202cdf00","type":"tab","label":"Flow 15","disabled":false,"info":"","env":[]},{"id":"ed9404a32493f348","type":"inject","z":"f34f56a1202cdf00","name":"button 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 1","payloadType":"str","x":240,"y":240,"wires":[["fa397cd50e53da64"]]},{"id":"5d44870ef3d8fcc9","type":"debug","z":"f34f56a1202cdf00","name":"relay 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":890,"y":240,"wires":[]},{"id":"542ec01399d74cdf","type":"inject","z":"f34f56a1202cdf00","name":"button 2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 2","payloadType":"str","x":240,"y":300,"wires":[["fa397cd50e53da64"]]},{"id":"f6aac4011f02294d","type":"inject","z":"f34f56a1202cdf00","name":"button 3","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 3","payloadType":"str","x":240,"y":360,"wires":[["fa397cd50e53da64"]]},{"id":"504994e68a6fd402","type":"debug","z":"f34f56a1202cdf00","name":"relay 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":890,"y":300,"wires":[]},{"id":"8ab0c75a9b116c02","type":"debug","z":"f34f56a1202cdf00","name":"relay 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":890,"y":360,"wires":[]},{"id":"4974e765e65fc82b","type":"switch","z":"f34f56a1202cdf00","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"button 1","vt":"str"},{"t":"eq","v":"button 2","vt":"str"},{"t":"eq","v":"button 3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":650,"y":300,"wires":[["5d44870ef3d8fcc9"],["504994e68a6fd402"],["8ab0c75a9b116c02"]]},{"id":"fa397cd50e53da64","type":"trigger","z":"f34f56a1202cdf00","name":"","op1":"","op2":"0","op1type":"pay","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":440,"y":300,"wires":[["4974e765e65fc82b","07583bb85bf30d06"]]},{"id":"7b5fb12647fcae7d","type":"inject","z":"f34f56a1202cdf00","name":"button ","props":[{"p":"reset","v":"reset","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":230,"y":460,"wires":[[]]},{"id":"07583bb85bf30d06","type":"delay","z":"f34f56a1202cdf00","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":620,"y":460,"wires":[["e5419a445b1844ec"]]},{"id":"e5419a445b1844ec","type":"function","z":"f34f56a1202cdf00","name":"Send 'reset'","func":"msg.reset = \"reset\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":560,"wires":[["fa397cd50e53da64"]]},{"id":"1a3d81f05446697a","type":"comment","z":"f34f56a1202cdf00","name":"Change this to 120 sec","info":"","x":660,"y":400,"wires":[]}]
So I correct my node with sugestions but nothing happened.
I setup trigger for 5 seconds to test it but with trigger node on the startup it's only delay time for 5 seconds from push button to working rest of the code.
My goal is as follow:
we have 3 physical buttons:
Yellow button - to start some sequence with relays - working time 120 seconds
Blue button - to start some sequence with relays - working time 120 seconds
Red button - to start some sequence with relays - working time 120 seconds
When I push for example blue button and start some sequence for 120 seconds I want to prevent to push other buttons to start yellow button and red button sequence when blue button sequence is working at the moment. when the sequence is over I can again choice which of 3 sequences I can use
please export your flow and attach it to a response and I'll take a look.
(That's what mine did) :wink:
So it does - just imported your flow.
The problem with the flow as is, that the relay/s will never be turned off.
You need to do just a bit more between the switch node and the GPIO-OUT node.
Basically you need a function node to receive the message and toggle what is sent to the GPIO pin.
One on each of the outputs.
(code in the function node as best I can make it just now)
let x = context.get("state") || 0;
x = (x + 1)%2;
context.set("state",x);
msg.payload = x;
Great minds think alike.
(Or is it: fools seldom differ?)
:wink:
Try this:
[{"id":"fa397cd50e53da64","type":"trigger","z":"0918ee609bf69fc7","name":"","op1":"","op2":"0","op1type":"pay","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":2900,"y":3950,"wires":[["4974e765e65fc82b","5208e2ef16afd9b6"]]},{"id":"ed9404a32493f348","type":"inject","z":"0918ee609bf69fc7","name":"button 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 1","payloadType":"str","x":2700,"y":3890,"wires":[["fa397cd50e53da64"]]},{"id":"542ec01399d74cdf","type":"inject","z":"0918ee609bf69fc7","name":"button 2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 2","payloadType":"str","x":2700,"y":3950,"wires":[["fa397cd50e53da64"]]},{"id":"f6aac4011f02294d","type":"inject","z":"0918ee609bf69fc7","name":"button 3","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"button 3","payloadType":"str","x":2700,"y":4010,"wires":[["fa397cd50e53da64"]]},{"id":"90312086218313de","type":"change","z":"0918ee609bf69fc7","name":"","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3070,"y":4060,"wires":[["fa397cd50e53da64"]]},{"id":"4974e765e65fc82b","type":"switch","z":"0918ee609bf69fc7","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"button 1","vt":"str"},{"t":"eq","v":"button 2","vt":"str"},{"t":"eq","v":"button 3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":3110,"y":3950,"wires":[["566dbfc5ddf752d7"],["17791fe1e8c5822f"],["db9ec301df7146f5"]]},{"id":"5208e2ef16afd9b6","type":"delay","z":"0918ee609bf69fc7","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":3050,"y":4020,"wires":[["90312086218313de"]]},{"id":"566dbfc5ddf752d7","type":"function","z":"0918ee609bf69fc7","name":"function 1","func":"let x = context.get(\"state\") || 0;\n\nx = (x + 1) % 2;\ncontext.set(\"state\", x);\n\nmsg.payload = x;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3290,"y":3890,"wires":[["5d44870ef3d8fcc9"]]},{"id":"17791fe1e8c5822f","type":"function","z":"0918ee609bf69fc7","name":"function 2","func":"let x = context.get(\"state\") || 0;\n\nx = (x + 1) % 2;\ncontext.set(\"state\", x);\n\nmsg.payload = x;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3300,"y":3950,"wires":[["504994e68a6fd402"]]},{"id":"db9ec301df7146f5","type":"function","z":"0918ee609bf69fc7","name":"function 3","func":"let x = context.get(\"state\") || 0;\n\nx = (x + 1) % 2;\ncontext.set(\"state\", x);\n\nmsg.payload = x;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3300,"y":4010,"wires":[["8ab0c75a9b116c02"]]},{"id":"5d44870ef3d8fcc9","type":"debug","z":"0918ee609bf69fc7","name":"relay 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3490,"y":3890,"wires":[]},{"id":"504994e68a6fd402","type":"debug","z":"0918ee609bf69fc7","name":"relay 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3490,"y":3950,"wires":[]},{"id":"8ab0c75a9b116c02","type":"debug","z":"0918ee609bf69fc7","name":"relay 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3490,"y":4010,"wires":[]}]
Change the 5 seconds to 120 of course.
Thank you for such support I am very grateful for your time.
So I attach photo of my desk to test
You can see that I want to make sequences for each buttons: for example when I push blue button the sequence starts: 10 seconds to open relay number 1, 2, and then relay 1, 2 close and relay number 5, 7 open for 15 seconds, and then relay number 10, 11 open for specific time. I have to think also to add rgb light to this and sound. So it will be the whole sequence for one button during 120 seconds.
my code is below
        "id": "a7c04de751f0d70c",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "71c5874690970252",
        "type": "inject",
        "z": "a7c04de751f0d70c",
        "name": "RED-ON",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "payloadType": "num",
        "x": 300,
        "y": 280,
                "40df411fb5f96a2c"
        "id": "40df411fb5f96a2c",
        "type": "rpi-gpio out",
        "name": "GPIO 17 - RED",
        "pin": "17",
        "set": true,
        "level": "0",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 560,
        "y": 280,
        "id": "46de8f397d8c30a1",
        "type": "inject",
        "name": "RED-OFF",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 300,
        "y": 320,
                "40df411fb5f96a2c"
        "id": "ef66caf2b21542a9",
        "name": "GPIO 27 - BLUE",
        "pin": "27",
        "set": true,
        "level": "0",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 560,
        "y": 400,
        "id": "b88acd49fd7f9063",
        "type": "inject",
        "name": "BLUE-ON",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 300,
        "y": 380,
                "ef66caf2b21542a9"
        "id": "cba5f36ac3613151",
        "type": "inject",
        "name": "BLUE-OFF",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 300,
        "y": 420,
                "ef66caf2b21542a9"
        "id": "033fcf1c4f2338fe",
        "type": "inject",
        "name": "GREEN-ON",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 310,
        "y": 480,
                "ac23678b6847aab2"
        "id": "02863a3a36443f1f",
        "type": "inject",
        "name": "GREEN-OFF",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 310,
        "y": 520,
                "ac23678b6847aab2"
        "id": "ac23678b6847aab2",
        "name": "GPIO 23 - GREEN",
        "pin": "23",
        "set": true,
        "level": "0",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 570,
        "y": 500,
        "id": "00220d4e445fbed3",
        "name": "GPIO 18 - 1 relay",
        "pin": "18",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 640,
        "id": "b4d9913244bee701",
        "type": "inject",
        "name": "GPIO 18 - 1 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 620,
                "00220d4e445fbed3"
        "id": "6c678d10e23c9564",
        "type": "inject",
        "name": "GPIO 18 - 1 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 680,
                "00220d4e445fbed3"
        "id": "180611fd8dd658ca",
        "type": "inject",
        "name": "GPIO 4 - 2 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 740,
                "22f07224c42d5ae0"
        "id": "a03b07af069d06d8",
        "type": "inject",
        "name": "GPIO 4 - 2 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 800,
                "22f07224c42d5ae0"
        "id": "22f07224c42d5ae0",
        "name": "GPIO 4 - 2 relay",
        "pin": "4",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 580,
        "y": 760,
        "id": "86ec22e13688bf46",
        "type": "inject",
        "name": "GPIO 22 - 3 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 860,
                "20f17aa86bd3900d"
        "id": "3094eac688372230",
        "type": "inject",
        "name": "GPIO 22 - 3 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 920,
                "20f17aa86bd3900d"
        "id": "20f17aa86bd3900d",
        "name": "GPIO 22 - 3 relay",
        "pin": "22",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 880,
        "id": "c75f3d81966f4a42",
        "type": "inject",
        "name": "GPIO 5 - 4 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 980,
                "a22644f09c453d6b"
        "id": "546bed0d4a38a0c7",
        "type": "inject",
        "name": "GPIO 5 - 4 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 1040,
                "a22644f09c453d6b"
        "id": "a22644f09c453d6b",
        "name": "GPIO 5 - 4 relay",
        "pin": "5",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 580,
        "y": 1000,
        "id": "dc30e5217dcba658",
        "type": "inject",
        "name": "GPIO 6 - 5 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1100,
                "b97a719da33147cc"
        "id": "eda1bbe67363472f",
        "type": "inject",
        "name": "GPIO 6 - 5 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 1160,
                "b97a719da33147cc"
        "id": "b97a719da33147cc",
        "name": "GPIO 6 - 5 relay",
        "pin": "6",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 580,
        "y": 1120,
        "id": "fb89175ab1fb44d6",
        "type": "inject",
        "name": "GPIO 13 - 6 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1220,
                "9e44fc7bb5a6f6c7"
        "id": "1e429d2368eb3d50",
        "type": "inject",
        "name": "GPIO 13 - 6 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 1280,
                "9e44fc7bb5a6f6c7"
        "id": "9e44fc7bb5a6f6c7",
        "name": "GPIO 13 - 6 relay",
        "pin": "13",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 1240,
        "id": "692677f4f265f945",
        "type": "inject",
        "name": "GPIO 19 - 7 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1340,
                "a162c62bf410cb2f"
        "id": "2cc69d3a52ca883e",
        "type": "inject",
        "name": "GPIO 19 - 7 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 1400,
                "a162c62bf410cb2f"
        "id": "a162c62bf410cb2f",
        "name": "GPIO 19 - 7 relay",
        "pin": "19",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 1360,
        "id": "a18f6efe250b26c7",
        "type": "inject",
        "name": "GPIO 24 - 8 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1460,
                "abf0336989dd502b"
        "id": "65a68a9793e78878",
        "type": "inject",
        "name": "GPIO 24 - 8 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 1520,
                "abf0336989dd502b"
        "id": "abf0336989dd502b",
        "name": "GPIO 24 - 8 relay",
        "pin": "24",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 1480,
        "id": "ea7b7e54ea9c3542",
        "type": "inject",
        "name": "GPIO 25 - 9 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1580,
                "c89736665c727dd6"
        "id": "80e0b13e899f352d",
        "type": "inject",
        "name": "GPIO 25 - 9 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 1640,
                "c89736665c727dd6"
        "id": "c89736665c727dd6",
        "name": "GPIO 25 - 9 relay",
        "pin": "25",
        "set": false,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 1600,
        "id": "2971eb4001b641ea",
        "type": "inject",
        "name": "GPIO 12 - 10 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1700,
                "755919522cdeadca"
        "id": "994f20862b19b7d4",
        "type": "inject",
        "name": "GPIO 12 - 10 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 350,
        "y": 1760,
                "755919522cdeadca"
        "id": "755919522cdeadca",
        "name": "GPIO 12 - 10 relay",
        "pin": "12",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 1720,
        "id": "eef14abb7f1f0943",
        "type": "inject",
        "name": "GPIO 16 - 11 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1820,
                "a782108a520dd316"
        "id": "b2c37c4ac1def429",
        "type": "inject",
        "name": "GPIO 16 - 11 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 350,
        "y": 1880,
                "a782108a520dd316"
        "id": "a782108a520dd316",
        "name": "GPIO 16 - 11 relay",
        "pin": "16",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 1840,
        "id": "6d06cd5560b2d01c",
        "type": "inject",
        "name": "GPIO 12 - 12 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 1940,
                "34160d1c4ca0d429"
        "id": "26b7778655c61dfa",
        "type": "inject",
        "name": "GPIO 12 - 12 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 350,
        "y": 2000,
                "34160d1c4ca0d429"
        "id": "34160d1c4ca0d429",
        "name": "GPIO 20 - 12 relay",
        "pin": "20",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 1960,
        "id": "785c3c87278d24d1",
        "type": "inject",
        "name": "GPIO 26 - 13 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 2060,
                "058763cf1630e937"
        "id": "985b6a325e9fc820",
        "type": "inject",
        "name": "GPIO 26 - 13 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 350,
        "y": 2120,
                "058763cf1630e937"
        "id": "058763cf1630e937",
        "name": "GPIO 26 - 13 relay",
        "pin": "26",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 2080,
        "id": "1b920d2c6466dd9b",
        "type": "inject",
        "name": "GPIO 21 - 14 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 2180,
                "687597d052585521"
        "id": "58f2127b06970b19",
        "type": "inject",
        "name": "GPIO 21 - 14 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 350,
        "y": 2240,
                "687597d052585521"
        "id": "687597d052585521",
        "name": "GPIO 21 - 14 relay",
        "pin": "21",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 2200,
        "id": "281aeb11f1837b3c",
        "type": "inject",
        "name": "GPIO 10 - 15 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 2300,
                "2a5f093afde59f9f"
        "id": "14486318ad2799a5",
        "type": "inject",
        "name": "GPIO 10 - 15 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 350,
        "y": 2360,
                "2a5f093afde59f9f"
        "id": "2a5f093afde59f9f",
        "name": "GPIO 10 - 15 relay",
        "pin": "10",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 2320,
        "id": "122b28cd8178aaae",
        "type": "inject",
        "name": "GPIO 9 - 16 relay [ON]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "x": 340,
        "y": 2420,
                "61dc8a60d5b5dcc5"
        "id": "01021f15b5af9107",
        "type": "inject",
        "name": "GPIO 9 - 16 relay [OFF]",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "1",
        "x": 340,
        "y": 2480,
                "61dc8a60d5b5dcc5"
        "id": "61dc8a60d5b5dcc5",
        "name": "GPIO 9 - 16 relay",
        "pin": "9",
        "set": true,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 590,
        "y": 2440,
        "id": "13cd8768c66047f5",
        "type": "rpi-gpio in",
        "name": "GPIO 11 - Yellow Button",
        "pin": "11",
        "intype": "tri",
        "debounce": "100",
        "read": false,
        "bcm": true,
        "x": 900,
        "y": 2620,
                "61fa470f1877e278"
        "id": "33eff1e864e8377e",
        "pin": "9",
        "set": false,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 1570,
        "y": 2600,
        "id": "4620a3d01878af9b",
        "name": "GPIO 14 - Blue Button",
        "pin": "14",
        "intype": "tri",
        "debounce": "100",
        "read": false,
        "bcm": true,
        "x": 900,
        "y": 2700,
        "id": "6b3c06b7f78b94e4",
        "name": "GPIO 15 - Blue Button",
        "pin": "15",
        "intype": "tri",
        "debounce": "100",
        "read": false,
        "bcm": true,
        "x": 900,
        "y": 2780,
        "id": "db0502faea8be49f",
        "pin": "10",
        "set": false,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 1570,
        "y": 2680,
        "id": "cc4bb08dbcf7e3cf",
        "pin": "21",
        "set": false,
        "level": "1",
        "freq": "",
        "out": "out",
        "bcm": true,
        "x": 1570,
        "y": 2760,
        "id": "61fa470f1877e278",
        "type": "trigger",
        "op1": "",
        "op2": "0",
        "op1type": "pay",
        "op2type": "str",
        "duration": "0",
        "extend": false,
        "overrideDelay": false,
        "units": "ms",
        "reset": "",
        "bytopic": "all",
        "topic": "topic",
        "outputs": 1,
        "x": 1140,
        "y": 2620,
                "72ac56deb16e20c9",
                "fa8a042992930565"
        "id": "7ad0d6f4b25968fc",
        "type": "function",
        "name": "Send 'reset'",
        "func": "msg.reset = \"reset\";\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1130,
        "y": 2440,
                "61fa470f1877e278"
        "id": "72ac56deb16e20c9",
        "type": "switch",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "GPIO 11 - Yellow Button",
                "vt": "str"
                "t": "eq",
                "v": "GPIO 14 - Blue Button",
                "vt": "str"
                "t": "eq",
                "v": "GPIO 15 - Blue Button",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 3,
        "x": 1350,
        "y": 2620,
                "33eff1e864e8377e"
                "db0502faea8be49f"
                "cc4bb08dbcf7e3cf"
        "id": "fa8a042992930565",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1340,
        "y": 2500,
                "7ad0d6f4b25968fc"
Trying_to_learn
I have just tried your code but with no result
